Old 05-20-2007, 06:22 PM   #1
mudmizer
mudmizer's Avatar
aluminum plug stuck
I was told not to do it but I did. I need to get an aluminum plug out of an aluminum manifold but the allen inset wants to strip out. It has not stripped yet, but feel like it will. I'm afraid to use heat on the aluminum.
Any ideas?
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 05-20-2007, 06:34 PM   #2
kwmech
Re: aluminum plug stuck
Use heat. What do you have to heat it up?
Old 05-20-2007, 06:38 PM   #3
mudmizer
mudmizer's Avatar
A torch. Will it discolor the manifold?
Old 05-20-2007, 06:59 PM   #4
71swb4x4
71swb4x4's Avatar
Can you run the truck? Drive it around the block a few times. It will only heat it 100 degrees or so but it may be hot enough to get it loose.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-22-2007, 01:59 AM   #5
mudmizer
mudmizer's Avatar
Thanks guys, using heat was the ticket. I used a good heat gun and heated around the plug. It was spooky going but it worked.
Thread Tools
Display Modes
