Old 05-23-2007, 06:25 PM   #1
kid66
kid66's Avatar
Laying frame.
I am new to this forum and need some help. What do I need to do to the front end of my 66 C-10 to make it lay frame. I have the rear to lay but I am still about 3" high in the front, from laying frame. Thanks for the help.
kid66 is offline   Reply With Quote
Old 05-23-2007, 07:39 PM   #2
Slmd92DIME
Slmd92DIME's Avatar
Re: Laying frame.
You need to cut your frame in front of the firewall and raise it. I did a 4 inch Z on mine. My bags have a cup on the bottom and a plate on the top. I also have a 3 inch drop spindle from summit. I also had to replace my tranny crossmember for my 3 speed. I now have a 350 turbo so I kept that crossmember above the framerails. The carrier bearing crossmember will also need raised. I also lowered my cab mounts an inch so it will be close to laying rocker. Its a job but its worth it.
Slmd92DIME is offline   Reply With Quote
Old 05-23-2007, 09:39 PM   #3
kid66
kid66's Avatar
Re: Laying frame.
I don't want to Z the frame!!!! Both center Crossmembers are home made it's just the front on I don't know what to do with. I don't have a carrier bearing but I did move up the trailing arm crossmember. Is there any other way to get 3" out of teh front with out Zing the frame????
Old 05-23-2007, 10:38 PM   #4
SCOTI
SCOTI's Avatar
Re: Laying frame.
Replace your original front crossmember w/a Porterbuilt unit.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-24-2007, 05:43 PM   #5
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Laying frame.
Do the control arms almost touch the ground in front? If so, section your front crossmember and it should help without z'ing the frame.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 05-24-2007, 07:13 PM   #6
jimmydean
jimmydean's Avatar
Re: Laying frame.
The only way to go IMO.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-24-2007, 07:51 PM   #7
lvscott
Re: Laying frame.
lvscott is offline   Reply With Quote
Old 05-24-2007, 08:57 PM   #8
kid66
kid66's Avatar
Re: Laying frame.
the control arms are about 1/2 off the ground so if I remove the front crossmember and cut 2" of it and reinstall it I should not have ot Z the front??I will not spent $1,200 for a Poterbuilt unit, when I can do the work myself. My I i should have just bulit a S-10.
Old 05-24-2007, 09:01 PM   #9
Chevysdominate
Chevysdominate's Avatar
Re: Laying frame.
No need to get nasty!
Chevysdominate is offline   Reply With Quote
Old 05-24-2007, 09:15 PM   #10
kid66
kid66's Avatar
Re: Laying frame.
LOL getting nasty?? ON a S-10 I would not have to Z the frame to make it lay frame. Just a set of cups and spindles.
Old 05-24-2007, 09:20 PM   #11
lowrollin70gmc
Too many projects
Re: Laying frame.
I don't know how far you can section, most say 1.375"-1.5", but here are a few links. I plan on a 2" section, but I will be doing much more fabrication along with that section, such as raising my steering box, moving front end 1" forward, etc.
Anyways, links:
http://www.captkaoscustoms.com/chopcross.html
http://67-72chevytrucks.com/vboard/s...d.php?t=229081
http://67-72chevytrucks.com/vboard/s...d.php?t=196019
There are a few more out there that I don't have links too. Search using terms: crossmember section, crossmember notch, sectioning crossmember, etc. and it should help you out. (Use the forum search just above the announcements, not the google/messageboard search on the top of the page.)
Andrew
Old 05-24-2007, 09:55 PM   #12
jimmydean
jimmydean's Avatar
Re: Laying frame.
If you can built something like a dropmember, then more power to you. There are a few members on here with well sectioned crossmembers, but there is more to it than just cutting and welding.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-24-2007, 10:12 PM   #13
PBFAB.COM
PBFAB.COM's Avatar
Re: Laying frame.
The price has gone up a little!
I would rather Z a frame than section a crossmember. Of course we all know the way I would do it!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-24-2007, 10:28 PM   #14
kid66
kid66's Avatar
Re: Laying frame.
I will call Laughlin Performance in the morning and ask Mike what he thinks. Thanks for all the help guys.
Old 06-01-2007, 01:09 PM   #15
revn67
revn67's Avatar
Re: Laying frame.
and that is why everyone and their mother "custom fabs" an s-10.....it is the honda civic of the truck world in my opinion! bolt on some things and it can lay, i know around here they're a dime a dozen and c-10's are nowhere to be seen!
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 06-01-2007, 02:48 PM   #16
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: Laying frame.
I sectioned my crossmember 1.25" and Zed the frame 3". Can I ask why you're against Zing the frame?
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-01-2007, 03:22 PM   #17
Shane
Shane's Avatar
Re: Laying frame.
Shoulda built an S-10? now that would be different.
Shane is offline   Reply With Quote
Old 06-01-2007, 10:41 PM   #18
kid66
kid66's Avatar
Re: Laying frame.
I don't want to Z the frame because I want to have a semi stock frame laying on 22's. Zing is cool but there is always a better way to lay on 22's without Zing. And back to the S-10 thing I have had two S-10's on bags laying frame on 22's and with all fabed parts and no bolt on. I have owned my 66 C-10 for 10 years now and I had it bagged for about that long. When I first bagged it I just replaced the stock spring with the air bags. But now it's time to make it lay frame without Zing.
Old 06-01-2007, 11:31 PM   #19
Shane
Shane's Avatar
Re: Laying frame.
you won't lay frame on these trucks on a stock frame without a Z, a porterbuilt unit, OR a sectioned cross member.
sorry to be the one to break the bad news to ya.
good luck kid
Old 06-02-2007, 10:32 AM   #20
BACKYARD88
BACKYARD88's Avatar
Re: Laying frame.
good luck kid
I have to agree with Shane on this one. I sectioned my crossmember 1.25" and there isn't room to section more than another 1/2" to 3/4" at the very most, granted I don't have drop spindles, but I was about 1" from laying with just the section on 17" wheels. Add 3" spindles and you're 1" from laying with 20" wheels. I'm not going to say it can't be done, but I couldn't find a way to do it. Good luck, and if you figure out a way let us know.
-Mike Owen-
Old 06-02-2007, 05:14 PM   #21
7deuce
Sold! 2 days after finished
7deuce's Avatar
Re: Laying frame.
Sell the 2 S10's and you might have enough for a Porterbuilt. Oh wait.....He did say he raised the price a little.
7deuce is offline   Reply With Quote
Old 06-03-2007, 07:35 AM   #22
kid66
kid66's Avatar
Re: Laying frame.
Lol!!!!
Old 06-03-2007, 09:16 AM   #23
royo
royo's Avatar
Re: Laying frame.
come on trucks laying frame
nickle and dime
royo is offline   Reply With Quote
Old 06-03-2007, 10:38 PM   #24
cajundragger
Re: Laying frame.
my brothers truck has a 1.25 sectioned crossmemeber and a 2.75 inch z and it lays 20's HARD. Frame looks stock as well by the time the core support and cab are on...
cajundragger is offline   Reply With Quote
Thread Tools
Display Modes
