Old 05-26-2007, 09:59 PM   #1
STL_66 Chevy
STL_66 Chevy's Avatar
newbie needs help!
hey i am a newbie here! and i need your help. i am doing a frame off on my 66 chevy and i cant get any of the bolts for the rear u bolts and spring bolts loose. i have tried penatrating oil, impact wrench, breaker bar and took the torch to it and no luck. anyone have any tricks that i might try? thanks for any advice.
STL_66 Chevy is offline   Reply With Quote
Old 05-26-2007, 10:03 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: newbie needs help!
Welcome to the board from South Mississippi! Oxygen-acetylene and a BFH is the only thing I can think of.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 05-26-2007, 10:56 PM   #3
bowtieguy61
use the torch to cut them, if they are that rusted you dont want to save them anyway.
61 swb step
63 swb fleet
bowtieguy61 is offline   Reply With Quote
Old 05-27-2007, 12:52 AM   #4
David Flores
David Flores's Avatar
Best bet it to just cut them off. I had to do that to a bunch of rusted bolts on my truck.
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 05-27-2007, 01:12 AM   #5
hewlett2002000
hewlett2002000's Avatar
yea, on my parts 62 every nut, bolt, and stud was rusted. the good ole grinder helped me alot!! lol but whats weird is my 66 nothings rusted on. so idk
good luck,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 05-27-2007, 07:26 AM   #6
GREASEMONKEY72
GREASEMONKEY72's Avatar
WELCOME to the board
just torch them off and put in some nice new ones
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-27-2007, 10:35 AM   #7
64GMCHorsepower
Justified!
Yep, I tried soaking mine in Kroil, WD-40, and nothing helped....
finally just used the die grinder and cut them off......5 minutes and your done!!!!!
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 05-27-2007, 11:59 AM   #8
STL_66 Chevy
i can cut the u bolts no probelm there but what about the bolts for the rear springs. if i cut them off then i have to buy new trail arms??? i dont want theat expense. any thoughts?? tha nk for you help
Old 05-27-2007, 06:14 PM   #9
pat66
pat66's Avatar
Cut'm Just went thru the same thing
U-bolts are not that expensive.Save the agravation and busted knuckels
Good luck
Pat
pat66 is offline   Reply With Quote
Old 05-27-2007, 06:17 PM   #10
pat66
pat66's Avatar
Spring bolts are replaceable
Thread Tools
Display Modes
