Old 05-31-2007, 01:22 PM   #1
one9six9
Junior Member
Fuel Tank Location.
I spoke with a guy that just replaced his fuel tank in his 68 GMC. His old one was full of trash. He replaced the sending unit at the same time. Once he was finished he noticed that the fuel/oil smell was gone from his truck. Possibly from the new sending unit gasket. He also mentioned that the fuel tank was only a 15 gallon tank. (I thought they were 20 gallon units.) We spoke about the tank being moved to the rear of the truck, but he wasn't willing to cut the hole in the fender.
My question or multiple questions are:
What are my options for the fuel filler hose? Other than the fender.
My tank has a lot of trash in it too. I stuck a new inline filter in the system and thought I would change it out a few times for a few months. Would it be wise to replace the tank?
I this is more of a novelty set up, but has anyone ever installed a tank under the bed, and also kept the tank behind the seat for a dual tank set up?
Keith
one9six9 is offline   Reply With Quote
Old 05-31-2007, 01:41 PM   #2
GMCBubba
GMCBubba's Avatar
Re: Fuel Tank Location.
try doing some searches of the forum. if you can think of it, it has probably been done. besides the fender, the other places i have seen them located are the stake pocket, the taillight housing, behind the license plate, and in the bed floor. use the search functions and you can find several FAQs on these things.
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 05-31-2007, 01:46 PM   #3
jimmydean
jimmydean's Avatar
Just put it IN the bed, it's so much easier that way.
I will be changing this very soon. You gotta love redneck PO's.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-31-2007, 01:58 PM   #4
Hart_Rod
Hart_Rod's Avatar
Keith, I've got a suburban tank that pretty much bolts under the rear bed without moving anything. There are several options with the fuel filler. We can discuss it when you come over to get the other parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=241593
R
Hart_Rod is offline   Reply With Quote
Thread Tools
Display Modes
