Old 06-05-2007, 04:47 AM   #1
cruisinlow67
Help with frame z on 67
now that i am almost finished with the rear of my 67 i need to move on to the front. im gonna get the frame z'ed and crossmember raised. how much should i raise both? what problems will i run into with engine placement, tranny placement,steering, and anything else? whats been your experiences? how much did it cost to have done? i already have a quote from the guy that did the rear of the truck but i wanna know what the usual price is.
cruisinlow67 is offline   Reply With Quote
Old 06-05-2007, 04:51 AM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: help with frame z.....
i believe you should do them both equally, and i dont think it affects the steering, the engine and tranny will be lifted up and need to be kept level with each other but other than that im not sure
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-06-2007, 12:45 AM   #3
cruisinlow67
ttt.....
Old 06-06-2007, 11:49 PM   #4
cruisinlow67
i forgot to mention that in the beginning i will be running 215/75/15 white walls. then i might switch to 18x8 smoothies. back to the top this goes.
Old 06-07-2007, 12:07 AM   #5
SCOTI
SCOTI's Avatar
Were you happy w/the work he's already done on your truck? If so, you're already money ahead even if his price is more than others.
How much did he quote you?
What exactly (in writing) will he be modifying?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-07-2007, 12:20 AM   #6
cruisinlow67
he quoted me $800 to z the frame,raise the crossmember, install the bags,fittings,valves and copper line for the front. yes i am happy with the work he did before.
Old 06-07-2007, 12:40 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Sounds like a fair deal to me if he does good work. There is a lot of hard labor involved in all of this. Does he know what he's getting into?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-07-2007, 12:43 AM   #8
SCOTI
SCOTI's Avatar
That's an understatement.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-07-2007, 12:45 AM   #9
PBFAB.COM
PBFAB.COM's Avatar
That's a lot of work for $800! If you have dealt with him in the past and have been pleased with the quality of work then he's your man.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-08-2007, 11:34 AM   #10
1lowdiesel
1lowdiesel's Avatar
Re: Help with frame z on 67
why copper line?
we were just talking about this and how it has a low tolerance for heat and it's softer. why not run stainless hardline?
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 06-29-2007, 07:30 PM   #11
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I Zd mine myself 2 3/4" and would def. pay someone I trusted $800 to do it.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 06-30-2007, 03:48 AM   #12
L0WRIDE
L0WRIDE's Avatar
$800 sounds cheap If you ask me theres a bit of work
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 06-30-2007, 09:05 AM   #13
cweber
Sorry to highjack the thread, but may i ask what z-ing the frame is?
cweber is offline   Reply With Quote
Old 06-30-2007, 09:11 AM   #14
cweber
Nevermind i found it. Why do you z the frame instead of body drop the truck?
Old 06-30-2007, 11:05 AM   #15
SCOTI
SCOTI's Avatar
Because on these trucks, the frame rail is already within 1" of the rockers. Body drops put the sheetmetal @ the lowest point instead of the frame rails & many would rather a frame rail drag on something vs. their sheetmetal.
'Tohmayto', 'Tuhmahto'..... They both accomplish similar results & there's alot of work involved either way you go.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-01-2007, 12:37 PM   #16
edflores
but body dropping make you lose more interior space. unless you stock floor body drop it. but 800 is dirt cheap for all the work thats involved. i was going to pay my friend 1000 just for the z. and i have seen copper line on trucks before, i think people use it because it is easier to work with and cheaper.
edflores is offline   Reply With Quote
Old 07-01-2007, 09:39 PM   #17
cweber
I see, thanks for the info.
Thread Tools
Display Modes
