06-08-2007, 06:39 PM | #1 |
The Hammer Man
fuel pump recommendation so i can go to the up coming meet
seriously thinking about going down to the meet but my fuel pump leaks a bit and if she sits it takes awhile to get the fuel back up to the carb so to be on the safe side i should change it if I dare to drive 8 hours to the meet.
There are sooo many fuel pumps on the market for my 350 and i dont know which to buy, i've been looking at ebay for a mechanical pump that will be a solid fit. Which to do you all recommend, and does anyone have a simple step by step install? I know for most of you this is a simple deal but i dont want to make a mistake to regret it on the side of highway north of St. Louis.
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
06-08-2007, 07:38 PM | #2 |
Re: fuel pump recommendation so i can go to the up coming meet
why pay shipping when any autopart store has stock type mechanical pumps in stock??? wagner acdelco etc are what i try but am not real particular as they are one of the most reliable dependable parts available on todays market
06-08-2007, 08:22 PM | #3 |
I will second that get one local. I use acdelco but anything will do.
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6 |
06-08-2007, 08:27 PM | #4 |
Dave's not here, man
I agree with cdowns. Just go to your local parts house and pick one up. They aren't too difficult to install. Disconnect your fuel lines from the fuel pump and unbolt the pump from the block. When you remove the fuel pump, the fuel pump rod may slide out, which isn't a big deal. If you have to reinstall the fuel pump rod, just put some heavy grease on it to keep it in place while you install the new fuel pump. Bolt the new pump to the block and reinstall your fuel lines. Hope this helps and that I didn't leave anything out.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
06-08-2007, 10:55 PM | #5 |
The Hammer Man
Thank you. exactly the advice i was looking for. So any auto parts will have my fp. Okay, thats what i'll do. ACDelco. people talked about using a l9nger bolt but if heavy grease will do the trick i'll try that.
appreciate it.
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T Last edited by Boise69; 06-08-2007 at 10:55 PM. |
06-08-2007, 11:24 PM | #6 |
its all about the +6 inches
I've had quite a few fuel pumps that would do that, even new ones. I've been told that it is normal, but it still seems odd to me.
Come to think of it, every small block chevy or big block caddy I've had would do this. Something to point out on the swap, on the small block, there is a bolt on the front of the block, down low up front, that if you remove it, and install a longer one, it'll hold the push rod up. Just remember to replace it with the short one and tighten it down, it'll puke a butt load of oil if you don't |
06-08-2007, 11:42 PM | #7 |
71 rustless in texas
that longer bolt will also bend the FP pushrod if left in so make sure that you remove it and put the shorter bolt back in, if you go this route.
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
06-08-2007, 11:45 PM | #8 |
It's the air up here
I agree. The through bolt hole is there, and use it. Makes it a 15-30 minute job on the stock pumps. Good idea GM!!!!
1971 cheyenne k10 4 speed np 205 454 BB factory a/c Never drink down stream of the herd! Eric |
06-08-2007, 11:47 PM | #9 |
The Hammer Man
Hell i just might buy it and bring it wit me cuz my truck runs good just as she is.
06-09-2007, 01:30 AM | #10 |
GEARHEAD
Someone will change it for ya there I'm sure. The tools will be on hand.
RJ22... |
06-09-2007, 01:35 AM | #11 |
Saving 1 truck at a time!
They are so inexpensive that it certainly won't hurt to carry a spare...I do. With these old trucks it is worth it to have a couple of spare parts to along in case of a random part failure.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
06-09-2007, 02:04 AM | #12 |
yea easy swap...me i swapped for a mechanical holley pump but like they siad they all pretty much the same..good luck,
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
06-09-2007, 03:33 AM | #13 |
grab one or two of the stocks ones and put one on and carry the other one with you
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
06-10-2007, 08:27 AM | #14 |
Change it. You can loose a lot of gas if it really goes bad. Or the gas could be going into your crankcase. I don't think you want to chance that for something you could have fixed for under 20 bucks. You can also use a thin blade like a hacksaw blade to hold the rod up as you slide the arm for the pump in.
Thread Tools | |
Display Modes | |
