i need help
so today my dd wouldent start. it is an 85 chevy s10 2.8l v6
i got in it and it turned over onec and now it wont. there is power to everything like lights raideo, ect. but it will not turn over what could be the problem . thanx colin
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
It's the air up here
Re: i need help
Ckeck volts on battery, if good then probably the starter. Could always be a loose connection too, so check all points of connection for tight, and corrosion.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
Re: i need help
ttt
Re: i need help
i agree with what eedgell said
when you turn the key does it click? or is it dead quite?
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Zappaphile!
Re: i need help
also check switch.. good luck
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
72 chevy
![]() Join Date: Jan 2007
Re: i need help
Turn the lights on and have someone watch them if thay go out when you turn the key then its the battery or cables but if it dose nothing and the lights stay bright then its the starter or wire problem.
Ed |
Dave's not here, man
Re: i need help
Maybe a bad starter solenoid??
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
The Crazy Machanic
Re: i need help
could it be a start fuse just a thought
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
Thread Tools | |
Display Modes | |
