Old 06-13-2007, 03:00 PM   #1
jdhcth
jdhcth's Avatar
Binary A/C safety switch voltage
I have installed my NAP Underdash unit in my 67 and I am about to vacuum/charge the system.
I mounted the Hi/Lo(binary) switch on the drier. I turned the ignition on and checked the voltage at the switch, not hooked to the compressor yet btw, and I have no voltage or a very small amount there, like 0.12v. I turned the fans on and turned the thermostat full cold....no change in voltage.
Question is: What voltage should I see there? What voltage does the compressor require from this switch?
It's fed off the same 12 volts as the fans, which work fine.
Thanks,
JD
jdhcth is offline   Reply With Quote
Old 06-13-2007, 04:21 PM   #2
Orange
Licensed to Thrill!
Orange's Avatar
Re: Binary A/C safety switch voltage
Just to be honest with you - I didn't even check mine when I did my install. (I have an underdash unit as well, not NAP).
But if it is new, I'd just go ahead with it. Make sure you have good connection and go. It's just a failsafe anyhow. Not really a "requirement" perse.
I don't think there is any way to check mine now that everything is hooked up and running...(without probing the wires).
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 06-14-2007, 07:07 PM   #3
jdhcth
jdhcth's Avatar
Thanks, I'm gonna vacuum and charge see if I did everything right.
JD
Old 06-14-2007, 07:18 PM   #4
RyanG
RyanG's Avatar
If you move the decimal to the right you have 12v. I would think you should get 12 volts though. Could be wrong but I too have never checked.
RyanG is offline   Reply With Quote
Old 06-14-2007, 07:40 PM   #5
jdhcth
jdhcth's Avatar
Good one. Maybe when the compressor is hooked up it completes it or somethin', I dunno. Or maybe is't got a resistor.
The NAP underdash unit, by the way, was a snap to install, checki it out. I also bought the high mount compressor bracket. Great stuff!
http://www.nostalgicairparts.com/getproduct.php?pid=351
JD
Old 06-14-2007, 07:43 PM   #6
RyanG
RyanG's Avatar
Nice ....I will have to save for that. I am just focused on my engine swap so that I can drive my truck again. I would love to do the body off restor but it is my DD and I don't have time at the moment. Sorry just blabn on....
Thread Tools
Display Modes
