Old 06-18-2007, 08:32 PM   #1
67CHIP72
STOLEN
67CHIP72's Avatar
Identify this part...
Located behind the drivers side front leaf.
In Search Of
67CHIP72 is offline   Reply With Quote
Old 06-18-2007, 08:35 PM   #2
corn
Re: Identify this part...
Some sort of a shackle limiter. Looks pretty cool, never seen anything like that before...
corn is offline   Reply With Quote
Old 06-18-2007, 08:53 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You see them on bigger trucks all the time, it's basicly a bump stop to keep the shackle from going back too far.
Old 06-18-2007, 08:57 PM   #4
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
or maybe used for off roading so you don't get hung up on a spring
'85 swb
droppedgmc is offline   Reply With Quote
Old 06-18-2007, 10:16 PM   #5
Rust Buster
Rust Buster's Avatar
I have it on my 72 K20, but it's only on one side. I was wondering what it is for as well. It's a solid chunk of metal
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 06-18-2007, 10:24 PM   #6
corn
You mean sorta like a shackle limiter?
Old 06-18-2007, 10:28 PM   #7
Longhorn Man
yes... just describing it a bit.
Old 06-18-2007, 10:32 PM   #8
67CHIP72
STOLEN
67CHIP72's Avatar
Holes in frame are on both sideson mine, but I only have the piece on drivers side.
In Search Of
Old 06-18-2007, 10:47 PM   #9
jhow66
jhow66's Avatar
I would say it there on 4x4's to keep the slip joint on front drive shaft from bottoming out.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-18-2007, 10:50 PM   #10
corn
Did all 4X4s have those?
Old 06-18-2007, 11:28 PM   #11
too much stuff
Roadtrip!
too much stuff's Avatar
That is a factory part found on the 4 wheel drives. Seems to me it had something to do with if a spring breaks, it would keep you from going into oncoming traffic. I think it was orginal held on with rivets. Also, only found on the drivers side.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 06-18-2007, 11:31 PM   #12
1969k10stepside
Yes,as too much stuff said...on the 4wds,drivers side only.There is also some metal welded on the drivers side front spring hanger to keep the spring in the spring hanger too.Most of the time that is trimmed off though because lift kit springs often have clearance issues with that metal on the spring hanger...
1969k10stepside is offline   Reply With Quote
Old 06-19-2007, 08:57 AM   #13
This was started in`71 on all K-models,driver side.
Old 06-19-2007, 10:17 AM   #14
jerry moss
Born Psycho
jerry moss's Avatar
just a little FYI. i once had a 71 cheyenne shortbed 4x4 that had them on both sides and also had straps on both front hangers--it all "appeared" to be factory installed. according to the vin on the cab, it was a stepside when built in 71 but when i bought it, it was a fleetside with all the trim. i know, anyone can add a bed and trim but this had been done a looooonnnnng time before i got the truck. after looking closer at the frame it became apparent it was a replacement, it had no vin number anywhere on it. then i pulled all the crap out of the cab and the floor was bent up very bad, so i guess the truck had been totaled when it was fairly new and someone pieced it back together.
anyone else have one with these brackets on both sides.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-19-2007, 10:31 AM   #15
67CHIP72
STOLEN
67CHIP72's Avatar
Mine only has the strap on the drivers side(front) as well. Thanks for all the input guys.
In Search Of
Old 06-19-2007, 10:33 AM   #16
1969k10stepside
Thats odd,my 69 4wd has one on the frame,I will look and see if its riveted on
Old 06-19-2007, 10:40 AM   #17
kwmech
It's on there because of the push pull steering.
Old 06-19-2007, 06:46 PM   #18
too much stuff
Roadtrip!
I think my 69 has one, and both my 70's have them. Drivers side only though.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 06-19-2007, 07:07 PM   #19
Do your pre-71s have the strap,too?I thought one of those was a recall in`71.
Old 06-19-2007, 08:26 PM   #20
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
That makes the most sense! Turning the steering wheel probably would cause like a bump-steer situation on the left front. The wheelbase would shorten slightly on that side with the bushing squish and shackle swing when steering right. Since the stock spring is arched upward, when you hit a bump the shackle swings away from that stop. The only time the shackle would swing towards that stop trail riding would be when the left front is being lifted off the ground.
My 70 Jimmy has it but there doesnt appear to be holes in the frame, altho the bracket has slotted holes. It is welded on.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Thread Tools
Display Modes
