Old 06-20-2007, 12:08 AM   #1
SactoJim
SactoJim's Avatar
Fuel Gauge ?
I have an aftermarket harness in my truck and was wondering if the factory fuel gauge sees 12 volts constant (with ign. in "on" position).
Are the 2 connections on the back of the gauge simply "hot" and "ground"?
So the basic wiring for this would be the wire from the sending unit to the gauge. The sending unit is grounded to the chassis (using fuel cell from "fuelcellguy"). The gauge gets a ground and do you just tap into run from the sending unit to the gauge with a 12 volt source?
Hope this all makes sense.....I'm not the brightest electrical guru!
I did do a search and read some of the "how too" links, etc... but couldn't find exactly what I was looking for.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 06-20-2007, 12:52 AM   #2
Chevelle454
Chevelle454's Avatar
Re: Fuel Gauge ?
I don't think you can just "tap" into the line, that will give you 12 volts constantly and defeat the purpose of the sender.
The way a factory fuel gauge is wired is as follows: The fuel gauge has three leads going to it, one hot, one ground, and one from the sender which contains a rheostat or potentiameter which goes to ground(tank is grounded).
I don't know what your aftermarket gauge or wiring looks like.
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 06-20-2007, 12:54 AM   #3
Chevelle454
Re: Fuel Gauge ?
Do you have a picture of the connections on your new gauge?
1972 C10
1972 C20
Old 06-20-2007, 12:57 AM   #4
cameeks
Long Fleet Club
cameeks's Avatar
Re: Fuel Gauge ?
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 06-20-2007, 01:09 AM   #5
SactoJim
SactoJim's Avatar
Re: Fuel Gauge ?
I'm using the factory fuel gauge and though I don't have it with me, it seems that the flat harness (not sure what to call it....flat blue laminated thing that connects to gauges and dash light) on the back of the cluster only attaches to the gauge at 2 points.
So what does the fuel gauge (factory) need to function properly?
- supercharged 383
- 4 wheel discs
My Build Thread
Old 06-20-2007, 01:20 AM   #6
Chevelle454
Re: Fuel Gauge ?
There is a single wire that used to go to your factory fuel tank sender. Hook that wire up to your new sender(in the fuel cell), plug the harness into your gauge cluster, and everything should work.
1972 C10
1972 C20
Old 06-20-2007, 01:23 AM   #7
Chevelle454
Re: Fuel Gauge ?
Oh and IIRC I believe the gauge is grounded through the cluster so you will only have two leads, 12v+ and the wire from the sender.
1972 C10
1972 C20
Old 06-20-2007, 06:11 AM   #8
byrd
Union Electrician
byrd's Avatar
Re: Fuel Gauge ?
if you use the factory printed circuit/ factory plug to apply the power and signal from your sending unit all you need to do is get the signal from the sending unit to the dash and it will be fine.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Thread Tools
Display Modes
