Old 09-17-2002, 05:06 PM   #1
Patch
Patch's Avatar
Unhappy Edelbrock 1406?
Hello again. I have a 1406 Edelbrock carb on my 72 Blazer with a 350. I just put HEI on it, and it was running good, however, now, it's starting to hesitate, and flatten out in a certain rpm range...i.e., running very rich. I checked all vacuum hoses, choke, and ignition...everything looks good. Here's what I did find.
When I took the air cleaner off and looked into the carburator, I see fuel puddled around the counter weights?? above and behind the secondary plates. Actually, it's at that level all the way around the inside of the carb....is my float sticking? It has always run rich, and this carb was on the blazer when I bought it. It's a 350, and the carb is a 625 cfm....My idle circuit is exactly at 2 1/2 turns...and that seems to be right...I can run them all the way in by hand, and nothing changes...except the engine almost dies.
How do you change a float level in one of these?
Any ideas would be great guys/gals...thanks....
Patch
Patch is offline   Reply With Quote
Old 09-17-2002, 05:26 PM   #2
71402BB
now thats a true COON DOG
well unfortunatly I can't help you on this one......... But I also have been having the same problem with mine! Thats strange I thought I was the only one. Althought I have not noticed a puddle but my idle circut is set just about the same as yours and I'm also running very rich! I hope someone here has some info that is more helpfull! But I also cannot understand why are carbs are doing this! DOES ANYBODY HAVE ANY IDEA WHAT IS CAUSING THIS TO HAPPEN, AND HOW IT CAN BE FIXED? Goodluck Patch
current project
67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!)
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well...
72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!)
68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!)
67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!)
71402BB is offline   Reply With Quote
Old 09-17-2002, 05:35 PM   #3
boilrman
70 Chevy 3/4t
carb
the 1406 edelbrock carb has very big jets in them. The primary is .095 and the secondary is .100 I have the same carb on my 350 and it sucks the gas big time, and runs rich. there is a kit you can buy to change the needles and jets and a graph is in the booklet than came with the carb to help you with what jets and needles as well as springs to use.
Find a job you love and you'll never have to work a day in your life.
1998 Yamaha V-Star 650
1970 Chevy 3/4t, I6 (rebuilt), 4 speed
Kokomo,IN
boilrman is offline   Reply With Quote
Old 09-17-2002, 06:14 PM   #4
kaycee
kaycee's Avatar
Talking Calabration Kit
When I pit my new carb on it was all messed up had 102 jets in the primary and 95 in the secondary.Swapped them around and it still hesitated so I bought the calibration kit.The graph in the book helped alot and thekit gives you several different spring's,metering rod's,jets to use then you should be able to dial it in.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 09-17-2002, 07:29 PM   #5
68 with 350 TPI
68 with 350 TPI's Avatar
Guys,
Are you running a fuel pressure regulator???????????????!????
Edelbrock/carter carbs are very VERY sensitive to fuel pressure.
Get a guage regulator combo from jegs for about 55$ and set it at about 4-5 PSI.
Dont go over about 6 PSI at the very most.(and I say that with the fact that every guage is not 100% accurate).
Anything over 6 PSI will push the neddle out of seat and it will stumble,run rich,and have part throttle problems.
After all most stock pumps push 7-9 PSI and that is enough to make a edelbrock run like POO
Try a real regulator with a guage and see what you think.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 09-17-2002, 10:16 PM   #6
boilrman
70 Chevy 3/4t
carb
Nobody has ever mentioned running a regulator with the carb. Cant say that I even saw it in the booklet on it.
Kokomo,IN
Old 09-17-2002, 11:36 PM   #7
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
it is in the book..around page 7 i think, it doesn't say to use a regulator, just says no more than 5.5psi..I can atest to the accuracy of 68's testimony, he alerted me to my problem...my stock fuel pump was pushing out 7psi and I was having all the same problems ya'll are... I bought the calibration kit at the same time and ended up taking it back because the regulator and guage cured me.
Suicide-D is offline   Reply With Quote
Old 09-17-2002, 11:39 PM   #8
Suicide-D
my set up
Old 09-18-2002, 08:23 AM   #9
Cheesewagon
Cheesewagon's Avatar
I thought it was just a junk carb. I've had trouble with mine ever since I went out west this spring. When your driving down the road I can smell raw gas all the time. Even with the electric choke it stumbles in the morning during warm up. So this could be the answer to my problem. Well if this fix's it, my hat is off to you, and thanks a million, Tom.
'91 suburban 350 TBI - R 700 4 new daily driver
'72 Cheyenne Super 49,000miles 350/350 frame up resto w/ matching numbers.
Cheesewagon is offline   Reply With Quote
Old 09-18-2002, 08:40 AM   #10
Jwill41
Jwill41's Avatar
I have the carter in my 68 on an early 80's 350 with stock fuel pump and it works great. The edelbrock is on my 67 with an electric pump and it farts and stumbles on a regular basis. I think I will go buy me the regulator for the 67.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 09-18-2002, 01:12 PM   #11
bubbastrick
Autozone
I have an Edelbrock 1405 on my truck. Does it have the same size jets in it as the 1406, or is the 1406 diferent just because it has an electric choke?
Do you guys know if I could purchase a regulator at Autozone or somewhere like that instead of ordering from Summit/Jegs? Also how much would one cost from the parts stores?
Would any stock vehicle have anything similar on it from the factory so I could just walk up and say "I need a fuel pressure regulator for a 19?? Chevy whatever" ? The guys at my local parts stores have to look everything up by year and vehicle, you can't just ask for a fuel pressure regulator.
James Strickland
AS Computer Information Systems
“Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge”
~E.J. Potter
bubbastrick is offline   Reply With Quote
Old 09-18-2002, 02:11 PM   #12
Suicide-D
I special ordered mine through O'Reilly Auto Parts the guage in my picture was boxed wrong so I sent it back and got the correct guage through O'reilly from Texas Performance, a wholesale performance distributor. You can get anything from your local parts store that you can get out of a catalog... the only limitation is you have to find a counterman willing to exert more effort than "No, I can't get that" atleast from O'Reilly's you can.
Old 09-18-2002, 04:39 PM   #13
68 with 350 TPI
You may look up in the phone book for a performance speed shop.
I have never had good luck with the local chain parts stores.
And even if you do get one through the local chain store like autozone,pep boys,etc you may pay a lot more for it.
Old 09-18-2002, 06:48 PM   #14
71402BB
Thumbs up
Thanks for the help guys! I would have never thought that to be the problem.......
current project
Old 09-18-2002, 11:39 PM   #15
Patch
Patch's Avatar
Talking Cool
I'm picking up my pressure regulator and guage in the morning....if it fixes it....I owe you. Thanks!
Patch
Old 09-19-2002, 07:47 AM   #16
Ed ke6bnl
Re: Cool
We picked one up at our local speed shop R@E Racing made by Holley for 25 dollars it had one in and 3 outs we put a 0-15 lb guage in one of the outs. This was done before the edelbrock was last week we will see how it all works. Eed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Thread Tools
Display Modes
