06-21-2007, 08:31 PM | #1 |
Need Pics of gas tank fillers inside the bed
I'm moving my tank from inside the cab to the under the Fleetside bed. Am using the LMC 21 gallon kit to do so.
My plan is once the tank is in place, to run a hose/filler neck up between the inside/outside bed walls on the driver's side and use a billet fuel door/cover. I'm trying to avoid mounting a door on the exterior quarter because of the welding/body/repainting it'll cause. Mounting the tank is straightforward, but before I go chopping holes in the driver's side inner bed wall, I'd like to see some of your filler caps and covers if they're mounted inside the bed between the tailgate and the fender. Thanks.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
06-21-2007, 09:10 PM | #2 |
Active Member
Re: Need Pics of gas tank fillers inside the bed
there is a thread here someplace about using a gas door of a s-10 you cut it down and mount it to the back of your side marker light
so it looks like a normal light but it opens and there you have your filler cap with cutting no holes in the outside of the box i dont rem what the conversion is called but its here someplace i am sure somebody else will chime in |
06-21-2007, 09:11 PM | #3 |
I just did this today. Just my approach, cause I don't want to re-paint.
http://67-72chevytrucks.com/vboard/s...d.php?t=246409
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 06-21-2007 at 09:11 PM. |
06-27-2007, 01:21 AM | #4 |
This is how I did mine. Used a 4" hole saw and used what i cut out to make the door; welded and smoothed a hinge, also welded on a simple tab. I've got magnets epoxied to the underside of the bed so it don't rattle. Maybe you dont want to cut your bed though...
'08 VW GTI- daily driver '74 CJ5 in pieces (4-bolt sb406/700R4 & 3/4ton running gear) '70 C10 W/ LS1 & 4L60E |
06-27-2007, 06:43 AM | #5 |
Here's a couple. Mine is the first one. The second one can be filled without removing the cap. Can be purchased from some hotrod vendors.
06-27-2007, 06:35 PM | #6 |
Thanks Lazybra1n. That is novel and wouldn't look bad at all under the gatorhyde/rhino liner I'm planning.
Mudder, your pics are real close to what I have in mind, but my bed is steel like Lazybra1n's. As such, a flat steel door wouldn't work in the corrugated flooring. But the setup would work fine in the bed side wall. Wonder how hard it would be to fill up with gas if the door were on the vertical inside wall instead of the horizontal floor, given that most modern pump nozzles have that springy foreskin collar thing on the nozzle. Last thing I'd want is to have to twist the nozzle in a precarious manner, have to use a funnel, or to have to trickle-fill the tank. I'm most impressed with ChevyDude's thread and his use of a marine deck filler setup. It looks really clean, is out of the way when hauling stuff, and out of sight as well. Thanks all for your inputs so far. Keep 'em coming though! Thanks.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 06-27-2007 at 06:38 PM. |
06-27-2007, 06:41 PM | #7 |
Active Member
neat idea with the magnets
06-27-2007, 06:59 PM | #8 |
Grafted in a lid from an early 90's olds. Got the electric solenoid and all so i just push a button and it pops up.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread Last edited by SactoJim; 10-04-2007 at 05:23 PM. |
06-27-2007, 07:06 PM | #9 |
I'm plannint to run a filler hose ove to the drivers side rear stake pocket upper. It seems like I saw a picture on here where someone did that.
SactoJim....that looks great! I especially like the attention to detail to nicely finish the edges of the ribs. |
06-27-2007, 11:14 PM | #10 |
I'm with ackattack, my plan is to invert a blazer filler and cover to fill from just below top of bed at stake pocket. That way if I'm hauling something (usually parts or camping and fishing stuff) I don't have to unload it to fill up.
'69 Chevy CST#'s 396/TH400, A/C |
06-27-2007, 11:57 PM | #11 |
Ok.... I'm getting older & all but those pics are messing w/my mind.
In SactoJims 1st pic, the yellow part of the floor looks like the low level; the shiny parts are the high level; & it looks like the door is attached to the high level areas. In the 2nd pic (once it's in primer), it looks like the door is now attached to the lower level of the floor. The 3rd pic looks like the 2nd.... only w/some shiny stuff on top. Is it just my eyes or ? ? ????????????
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-27-2007 at 11:57 PM. |
06-28-2007, 08:32 PM | #12 |
Ttt
06-28-2007, 09:51 PM | #13 |
I'm with you Scoti......the more you look the more decieving it becomes. It is on the high side rib.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
06-28-2007, 10:00 PM | #14 |
I know you are looking for bed options, but you should really see what HuggerCST did with his rear tank.
http://67-72chevytrucks.com/vboard/s...ight=HuggerCST Hope the link works.
CARPE CERVASIUM! 1968 C10 Fleetside LWB Remember Cthulu is watching you! / (@) (@) \ |
06-28-2007, 10:01 PM | #15 | |
That's great, I've got you scratching your head too. That looks pretty nice BTW.... pretty deceiving too!
07-20-2007, 07:25 PM | #16 |
Thanks all. Hugger CST's approach is certainly novel, but unless it's a "bolt-in", it's goiing to require more paint/body/welding fabrication that I'm willing to do for this go around. Don't get me wrong, it's excellent. Just not for me at this time.
Still collecting ideas though, keep em coming. Thanks.
07-20-2007, 08:25 PM | #17 |
Official Site Guitar Shredder
07-20-2007, 10:08 PM | #18 |
Here's a pic or two of my under the bed tank install with fuel filler. Works great, don't have to "trickle" the gas in and if I have items in the bed I don't have to move them to get to the fill cap.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
07-20-2007, 10:49 PM | #19 |
Fat Fendered Fleetside
here's mine.
Huggercst did what I realized about halfway modding it, that those flat led's sure would be nice. Both the fact that they're thin and that the wires come from the bottom makes a huge help if you go with a taillight filler. IF I would have known about those lights beforehand, I'd have used them. But I did manage to reuse the stock filler from the in-cab tank!
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
Thread Tools | |
Display Modes | |
