Old 06-24-2007, 11:38 PM   #1
hewlett2002000
hewlett2002000's Avatar
after 15 minutes of running it sputters and goes dead
ive got a problem with my truck. its got a 350/4-spd , holly 4bbl 600cfm. after it runs for about 15-20 minutes it sputters and goes dead like its out of gas, but i know its not. i can pump it a few times and it starts and just dies again. temp, oil pressure, everything is normal. it will start right up and run after an hour or so. i have no idea what is wrong. it has a brand new carb, intake, distributor, coil, and fuel pump. i just changed the plugs and wires and oil 2 months ago and it hasent been driven much since. i cant figure out whats wrong with it. please help.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 06-25-2007, 12:40 AM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: after 15 minutes of running it sputters and goes dead
Sound like a fuel flow issue. Have you replaced the filter, and checked the line for correct flow? I used to have a VW that sat for a long time, I found many clogged fuel filters, and it was rust breaking free in the tank and getting sucked into the fue line, clogging the filter. Was the truck just idleing, or out driving?
PrerunnerRob is offline   Reply With Quote
Old 06-25-2007, 12:45 AM   #3
PrerunnerRob
One more thing! Its rare, but I had a coil that had drained all the oil out of it, and it would get hot, and my coil would short out temporaly. As soon as it got cool, the coil would work again. Are you running a HEI, points, or a electronic ignition?
Old 06-25-2007, 05:35 AM   #4
60ratrod
yes, i do
60ratrod's Avatar
let me guess it only runs with the choke partially open/closed right?? it sounds like your carb may need to be re-tuned, which is difficult on holleys. i would personally switch to an edelbrock. i haven't had any problems at all since i have switched to edelbrocks and they are so much easier to tune than a holley.
60ratrod is offline   Reply With Quote
Old 06-25-2007, 08:59 AM   #5
LAFNATU
LAFNATU's Avatar
I had the same problem once before, I ran a hose straight to a gas can from the fuel pump just to see if it was the fuel line pluged up and it was...
LAFNATU is offline   Reply With Quote
Old 06-25-2007, 09:47 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
we need to know which distributor you have.. If you have an HEI the modulator might be bad and when it gets hot it shuts down and after it cools it will work again.. Or a bad coil like rob said. I had one leak down on a truck I had. It used to cut out as I was driving and sometimes just studder a bit and then shut down. Finally it just stopped working all together.. When I took the coil off I was able to shake it and hear the insides banging around in there..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-25-2007, 09:50 AM   #7
hyde
hyde's Avatar
Coil Issue.....I would be willing to bet!
06 Crew Cab GMC[/B] on 22's
07 Duramax 4x4 Lifted Maxed Out!
1972 2WD K5. 89k miles. Soon to be bagged, LS1 and bad!
1967 Short and Wide. Soon to be an LS1 and bagged
hyde is offline   Reply With Quote
Old 06-25-2007, 10:08 AM   #8
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
well....if it hade a M.A.F sensor,that's what it would be, but it dont....so im no help....sorry!
tiggerstoy is offline   Reply With Quote
Old 06-25-2007, 10:44 AM   #9
hewlett2002000
it has a HEI distributor. im pretty sure its not the coil because it was doing this before i changed from the points to the HEI. the holley is an electric choke. the truck was sitting for 4 years before i got it. the tank was completely gone. before i ever tried to start the truck i took the tank out and drained it and the gas was dark brown and the pickup line on the sender was rusted off and in the tank. i took the tank off my 62 parts truck which was in a lot better shape and put it on there. i wouldent doubt fuel flow issue. i changed the filter not to long ago. ill check all the fuel lines and replace all the rubber line. a friend of mine has a 65 swb fleet and he said he had a similar problem with the fuel line collapsing when it got hot. he said just put a spring around the hose behind the fuel pump. ive never heard of that but its worth a shot.
thanks ,
John
Respect:
Old 06-25-2007, 01:49 PM   #10
55dude
55dude's Avatar
it's the ignition module! sometimes they go out completely then other time they go out then cool down and will work again. i have have them do both.
55dude is offline   Reply With Quote
Old 06-25-2007, 02:07 PM   #11
baddawg65
baddawg65's Avatar
Fuel Pump or a leak in the line between the tank and pump.
baddawg65 is offline   Reply With Quote
Old 06-25-2007, 02:08 PM   #12
hewlett2002000
i thought that was in the distributor? if it is then i dont think thats it. it was doing it before i switched to the HEI.
Respect:
Old 06-25-2007, 02:36 PM   #13
baddawg65
baddawg65's Avatar
Trying loosing the gas cap also, tend to think fuel problem, because you say it will fire again by pumping the pedal. When it dies take the air cleaner off, shine a flashlight down the carb open the throttle and see if you get a good spray of fuel.
Old 06-25-2007, 03:21 PM   #14
hewlett2002000
i checked and its getting good flow on the carb side. i was planning on moving the tank to a cell in the bed anyway so i guess ill just do that. i can get a 25gal cell for $200 with sender. ill just put that in the bed and run new lines. i think it needs that bad. like i said the tank from the 62 was better but still trashy and rusty as hell inside. anyways i dont wanna ruin my new carb with that trashy ****.
thanks all,
John
Respect:
Old 06-25-2007, 04:38 PM   #15
baddawg65
baddawg65's Avatar
Here's how I did mine
Old 06-25-2007, 04:50 PM   #16
Luvlegs
Luvlegs's Avatar
Do the holleys have the filter in the side of the carb too?
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 06-25-2007, 05:32 PM   #17
60ratrod
yes, i do
60ratrod's Avatar
if i remember correctly, all it is is just a small brass screen where the fuel inlet is on the carb
Old 06-25-2007, 05:34 PM   #18
hewlett2002000
hey baddawg, nice setup. is that a custom tank? if not where did you get it? that looks great. my holley did not have the filter in the side.
thanks,
John
Respect:
Old 06-25-2007, 08:07 PM   #19
baddawg65
baddawg65's Avatar
It came from Brothers. Had to do a little custom work for shackle mounts on the frame 3/4 4x4 w/leaf springs and added a crossmember behind the tank. Drawback to the tank is the capacity.
Old 06-25-2007, 09:05 PM   #20
hewlett2002000
how many gallons does the stock tank hold full? i should know but ive never had enough money to fill it up!! lol
Respect:
Old 06-28-2007, 03:25 PM   #21
Volvo_Matt
Volvo_Matt's Avatar
I think a stock tank behind the seat holds 18 gallons.
1963 LWB 350 M-21 4spd comp/edelbrock/holly/LT1 1.94/1.60
Volvo_Matt is offline   Reply With Quote
Old 07-06-2007, 06:29 PM   #22
kris's66lwb
resident wrencher
i am having the same problem my 66 k20 with 327 and th350 will start run for 2 seconds and die but its running real lean it has a small 2bbl carb i need to know where the air fule mixture screw is and idle adjust screw is located and gass tanks were 18 19 and 21 galons thanks
kris's66lwb is offline   Reply With Quote
Old 07-07-2007, 09:09 AM   #23
mnunn454
mnunn454's Avatar
I'd guess vapor lock (fuel boiling in the line) or gas tank cap not breathing.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 07-07-2007, 02:24 PM   #24
kris's66lwb
resident wrencher
i fixed it i just adjusted the carb and wala he ran
Old 07-07-2007, 10:19 PM   #25
ZBS 64
ZBS 64's Avatar
Maybe vapor lock?
ZBS 64 is offline   Reply With Quote
Thread Tools
Display Modes
