how thick?
going to be having my work bend me up a c notch to use on my c-10 and was wondering what you guys might suggest to use for thickness. 1/4 or 3/16?
i was looking at some 3/16 and thought that it would be enough to do this with but would still like some expert advise, thanks steve |
Dave's not here, man
Re: how thick?
I looked on www.***************** and see that they use 1/4" for the smaller notches and 3/16" plate for the larger ones. How big of a notch are you needing?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
soon to be bagged64sub
Re: how thick?
With a small C notch I would use 1/4" but with a step notch you could use 3/16".
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: how thick?
I would say it depends on how it is designed. If it is designed properly you could use 3/16" for it. If you are pretty much doing it just like the ones you can buy, just stick with the material thickness they use. The cost/weight difference would be minimal.
Re: how thick?
thank you to all. it is going to be a basic c notch style that i will be welding in once i get power out to the garage. i was searching around at work the other day and found a good size piece of 1\4 inch that i can have and i will be making a blueprint to have the plasma table cut it out. then a couiple of 90 breaks and a weld in piece where the c notch cut is going to be and it will be done.
thanks for the input fellas. steve |
Thread Tools | |
Display Modes | |
