Old 07-01-2007, 03:29 PM   #1
harleyx2
redrilling axles
has anyone ever redrilled there axles to make them 5 lug? it looks easy.
harleyx2 is offline   Reply With Quote
Old 07-01-2007, 03:59 PM   #2
cdowns
cdowns's Avatar
Re: redrilling axles
its very easy to do // drop off at machine shop then the next day you pick them up
Old 07-01-2007, 06:37 PM   #3
sick69
sick69's Avatar
Don't forget to pay the man when you pick them up!
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 07-01-2007, 07:08 PM   #4
mvfd70
mvfd70's Avatar
What year truck do you have. Why not just swap axles or swap the rear end completely to get the 5 lug. I'm not convinced that welding the old holes and drilling new ones is the way to go. Just my opinion. I would think that would make it weaker. But i'm not a metal working guy so what do I know?
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 07-01-2007, 07:31 PM   #5
harleyx2
going to a machine shop or buying a new housing takes money. i dont see the need to pay a machine shop to do what i can do for free. i work with metal everyday and i used to work in a machine shop. i was just wondering if anyone else had done this theirself.
Old 07-01-2007, 09:40 PM   #6
Shane
Shane's Avatar
are you planning on doing this with a Black & Decker drill or do you have access to a knee mill?
Shane is offline   Reply With Quote
Old 07-01-2007, 10:23 PM   #7
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Mine was done when I got it, but unfortunately the shop or whoever redrilled em didn't get em correct
Instead of 5x5 it's like 5x4-5/8 So I can get any other wheels than universal 5 lugs... Grrrr
Also my studs are a little bit loose IMO
So I think as long as it's done "right" then it should be fine, but might be easier to change axels
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-02-2007, 12:11 AM   #8
raiders3581
Junior Member
raiders3581's Avatar
i had mine done by moss brothers in southern cal , they arent there anymore. Just so you know unless you have the pilot hub on the axle machined you will need to use a spacer becaust the 5 lug rim center is smaller. it cost me around 175.00 for both axles if i remeber right. i got tired of them and bought cpp axles and have a better feelling about it now. just my two pesos
67 short bed fleetside/1997 c1500 exteded cab/ 2004 accord/87 c10silverado 350 od tbi
raiders3581 is offline   Reply With Quote
Old 07-02-2007, 12:58 AM   #9
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
I have never drilled any truck axles from 6 to 5 bolt pattern but I have on a few different occasions drilled ford to chevy bolt pattern axles myself.
Do it right or you will be just wasting your time IMO buy the right bits and make sure of this as you will have to check with the stud manufaturer on what size is needed for there knurl to fit properly. BTW large bits in odd sizes are not cheap either.
If done properly it's NO different than paying someone else to do it. I.E. the right layout, ofcoarse straight, right size for stud knurl, ect. also as I stated I have never gone from 6 to 5 so I do not know where the pattern will fall on the axle in between the 6 hole some thing you will have to focuse on IMO.
RJ22...
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 07-02-2007, 01:52 AM   #10
GREASEMONKEY72
GREASEMONKEY72's Avatar
like others have said when its done right its no different than a machine shop doing it, just make sure you get all your measurements correct and youll be good
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-02-2007, 12:11 PM   #11
2500HD
2500HD's Avatar
redrilling is not the hard part. machining the axle flange is the hard part. I paid $180.00 to have mine done and I provided the new studs and new five lug brake drum so they had something to get the measurments from. If I had it to do over I would buy new axles.
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
Thread Tools
Display Modes
