Old 07-02-2007, 12:10 AM   #1
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Question Problems "pushing" the steering column forward
I read Putter's tech info in FAQ, and some other info I could find. I have a '72 Blazer tilt column I installed in my '69 C20 cab today. About 3/4" is all the further forward it will go, because the NSBU switch is TIGHT against the firewall. If I shove the column where I really want it (shift bowl against the cluster grommet) the NSBU switch would end up impossible to install, as it would be in the firewall. I suspect that those of you with an auto tilt column tight against the cluster have done away with the NSBU switch, relocated it requiring shift tube/ housing fabrication or used a van column that ends up with the switch on the outside of the firewall.
Or am I missing something
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 07-02-2007, 12:23 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Problems "pushing" the steering column forward
mine is a van unit, I did away with the switch.
If I start in in gear, I deserve to be shot anyways IMO.
Old 07-02-2007, 12:44 AM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
mine doesnt have the switch
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-02-2007, 05:58 PM   #4
Bob Moore
Jeffspower - You can retain the NS switch by moving it away from the original location. Follow the FAQ and move it UP the column the required amount.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Thread Tools
Display Modes
