Old 07-10-2007, 07:20 PM   #1
BAGGERSOCAL
Active Member
Is a C20 Cab the same as a C10 Cab
Found a clean 68 C20 Cab is the Cab the Same as a C10?
would like to change out my Cab on My C10 needs alot of work cab corners and floor .
the C20 looks pretty clean.
Steve
BAGGERSOCAL is offline   Reply With Quote
Old 07-10-2007, 07:45 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Is a C20 Cab the same as a C10 Cab
yep. The mounts aren't, but the difference is on the frame, not the cab.
Old 07-10-2007, 08:05 PM   #3
BAGGERSOCAL
Active Member
So everything in the Cab is the Same just the mounting Holes in the Cab.
Old 07-10-2007, 08:31 PM   #4
alskyline
alskyline's Avatar
Yes, You will be fine. The cab brackets on the frame sit lower on a C20 than on a C10. The cabs are the same. The difference is that when mounting a cab on a C20 frame you need a different bushing set than mounting on a C10 Frame. I believe you should be fine. Everything should match up!
alskyline is offline   Reply With Quote
Old 07-10-2007, 09:21 PM   #5
Longhorn Man
thanks for wording it better. I ended up explaining a bit more in PM... but you still put it in better words than I did.
Old 07-10-2007, 11:06 PM   #6
BAGGERSOCAL
Active Member
thanks for the info will buy the cab then
Thread Tools
Display Modes
