Old 07-12-2007, 02:14 PM   #1
BigSky71
LAIDOUT
BigSky71's Avatar
Up tight exhaust heats the floor, worry?
I have my exhaust installed through the cross member, its about 3" from the cab floor. My flowmasters are hung behind the cab a few inches in front of the rear-end. I drove down the block recently and in five minutes the cab floor was too hot to keep your hand it. You wouldn't notice with shoes on, but my wife came along and was bare-footed [that's how I keep her, lol] anyway I am thinking it would be smart to wrap the pipes in exhaust wrap fabric to keep the floor cooler. Plus I plan to mount my two amps under the seat, and they won't like sitting on a hot floor.
So has anyone had to wrap the exhaust to control the heat?
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 07-12-2007, 02:27 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Up tight exhaust heats the floor, worry?
I would build an exhaxust heat shield. Make a sheet-metal shield that mounts off the exhaust between it and the floor. The greater surface area of the shield, the better it will disipate the heat.
At least get your wife some socks!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-12-2007, 02:46 PM   #3
cdowns
cdowns's Avatar
the heat sheild idea is a good one tho i'd think more of using aluminum//a friend built a car with a 800+hp nascar cup engine and the exhaust was alot closer than 3" to the floor and he used stuff these guys provided. it worked good with no heatissues www.thermotec.com
Old 07-12-2007, 03:04 PM   #4
randomhero472
randomhero472's Avatar
i dont know where you can get them, im guessing summit.. but i've seen adhesive strips that are heat shields, looks a lot like dynomat and works good
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 07-12-2007, 03:23 PM   #5
swb85
On a budget like Fred Sanford
swb85's Avatar
I'm surprised you're having heat issues with 3" of clearance between the floor & pipes. My 3" duals tuck up a lot higher than that and my floor stays cool. I agree that a heat shield would be your best bet, you could make your own out of aluminum sheet metal pretty easily.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 07-12-2007, 11:51 PM   #6
jasonb72
PorterBuilt Man Crush
My interior guy told me about a ceramic coating that is applied on the inside cab on the floor and firewall. We are going to do it on mine when I get there. He said the guy that tested took two pieces of metal, one with and without the coating. He put ice cubes on the metal and hit the underside with heat. The one started melting instantly, and the other did not. Sounds like some good stuff.
jasonb72 is offline   Reply With Quote
Old 07-13-2007, 12:47 PM   #7
BigSky71
LAIDOUT
BigSky71's Avatar
Thanks for the suggestions, I think a heat shield is a great idea. I do have Second Skin Damplifier on the cab floor so there is some insulation, but its very surprising how hot it got... The truck idled about 5 minutes before I drove it so maybe it heat sinked while not moving, and it has been high 90s even up here in the mountain sticks.
67 2wd Shorty
Build Pictures
Old 07-13-2007, 12:50 PM   #8
BigSky71
LAIDOUT
BigSky71's Avatar
I will I promise .
67 2wd Shorty
Build Pictures
Thread Tools
Display Modes
