Old 07-13-2007, 11:57 PM   #1
BCOWANWHEELS
antbody runnin the msd setup ?
anybody got the msd ignition setup on there truck ? i was wondering if it really helps fuel milage ?
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 07-14-2007, 12:31 AM   #2
paaw
paaw's Avatar
Re: antbody runnin the msd setup ?
wanna know the same thing
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold
paaw is offline   Reply With Quote
Old 07-14-2007, 07:02 AM   #3
Jim_PA
I've never noticed any MPG gains.
Jim_PA is offline   Reply With Quote
Old 07-14-2007, 08:31 AM   #4
paaw
paaw's Avatar
well what about power wise, can you tell a difference in throttle response
Old 07-14-2007, 08:50 AM   #5
HomerJ
HomerJ's Avatar
I have a 6AL, but put it on shortly after a rebuild several years ago. I really can't say whether it provides better milage or performance, since I didn't measure performance or milage before installing it.
My best guess, though, is that an HEI or good aftermarket distributor with a quality coil would probably satisfy the needs of at least 95 percent of us. The biggest problem with the stock HEI is that the stock coil starts to fade around 4500 rpm. A good coil will take that number above 6000. I don't know about you guys, but my engine rarely goes over 5000 (those times are fun though!!!).
HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73
67 Chevelle SS Clone 454/TH400/3.73
HomerJ is offline   Reply With Quote
Old 07-14-2007, 11:35 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If you use msd carry along the stock hei set-up in the glove box I had the msd box go out and I was walking.....yep it sucked....BTW no milage gains that I could see..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-14-2007, 11:55 AM   #7
cdowns
cdowns's Avatar
from what i can see on a mild(less than 500hp) street driven machine pretty much a waste of money with no real advantages// advertising hype at its best
Old 07-14-2007, 12:42 PM   #8
BCOWANWHEELS
thanks for the help. guess i,ll just go with a good coil and be done with it.
bob
Old 07-15-2007, 12:32 AM   #9
yenko427
yenko427's Avatar
Are you running a HEI set up? My truck has HEI and I took the control module out and the MSD works in it's place. A standard HEI set up put out 45,000 volt. Before I installed the MSD I was fouling out spark plug. Since I installed the MSD I don't have a problem with fouled out plugs. The throttle response did get better but I'm still working on the carb. for adjustment in the jets. I did put bigger spark plug wires on with low resistance to get the most spark to the plugs.
yenko427 is offline   Reply With Quote
Old 07-15-2007, 01:36 AM   #10
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Thumbs up Re: antbody runnin the msd setup ?
I run an MSD box with Protronix ignition modual and a Protronix high out put coil in my 50' Chev. I had a real hard time starting this truck with points. I also would get a slight hesitation under hard acceleration. Once I put in the ignition goodies it started up right away and the hesitation was gone!! My reason for the ignition install was never because of fuel milage so I can't be of help there but MSD is supposed to causes fuel to be burned more completely giving you a bigger bang for your fuel buck and also burns fuel more competely which aids with the pollution issue.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 07-15-2007, 12:28 PM   #11
kelsfine69
18 Till I Die
kelsfine69's Avatar
check this out
http://www.pertronix.com/
I put one of these HEI flamethrowers in, plug and play replacement. All new parts and it works flawlessly. I hit 7000 rpms and never missed a beat. I think MSD is overrated I have seen too many of my buddies trying to fix, repair or setup...IMO
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Thread Tools
Display Modes
