Old 07-14-2007, 01:39 PM   #1
Green Machine
Green Machine's Avatar
Ammeter doesn't work - where to start ?
I have some spare gauges I can try, but before I take the dash out, aren't there some small fuses in the front harness that has something to do with the guage ?
PS - I had to push my truck, 71 c20 thru the drive thru line at McDonalds and out into the parking lot last night. The dog was in the front seat but could not drive, so I had to do it all myself. Pretty embarrassing. I have the alternator fixed now, (brush was stuck) but it would be nice to have the gauge fixed so I can keep an eye on it !!! Thanks
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-14-2007, 01:58 PM   #2
john
member #16
john's Avatar
Re: Ammeter doesn't work - where to start ?
There should be a fuse close to the junction block on pass side fender and the other in the vicinity of driver side headlight. They are 4 amp and the holders look like black footballs.
john is offline   Reply With Quote
Old 07-14-2007, 02:12 PM   #3
Green Machine
Thanks for the quick reply, I needed to verify if I was on the right track, was pretty sure those fuses connect to the gauge, I will try that first.
Old 07-15-2007, 12:56 AM   #4
Green Machine
Two new fuses and it works again ! The one by the battery was bad, sometimes the easy fix works ! Thanks.
Thread Tools
Display Modes
