Old 07-14-2007, 08:37 PM   #1
randomhero472
randomhero472's Avatar
Airlines thru front crossmember?
Im wondering how you guys are getting the airline's to the front bags.. might be a dumbass question, but i cant see my truck (500 miles away) at builder, but am about to order my front bags & fittings and wanted to make sure i got everything.. thanks
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 07-14-2007, 11:10 PM   #2
skunkwerx
skunkwerx's Avatar
Re: Airlines thru front crossmember?
yea my air line goes though the crossmember.
skunkwerx is offline   Reply With Quote
Old 07-15-2007, 12:14 AM   #3
itsmike2k
any pics? Did you use a passthrough or just drill a hole and run the line through.I have some PTC pass through fittings but i have to drill a 15/16 hole for them..
Mike
1972 LT1/4l60e Short Bed
ART Front and Rear Strong Arms
http://www.67-72chevytrucks.com/vboa...50#post2151750
itsmike2k is offline   Reply With Quote
Old 07-15-2007, 01:16 AM   #4
pissonNOS
senior member
pissonNOS's Avatar
i just used a step bit drilled a hole then covered the line in heater hose just in case
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 07-15-2007, 02:02 AM   #5
Frizzle Fry
Frizzle Fry's Avatar
I JUST did this today! I'll post pics tomorrow. I went through the rear of the spring perches just above the brake lines and used a 1/2" ID grommet for my 1/2" air-line. I thought about a bulkhead fitting but I figured fewer fittings = fewer possible places to leak.
Frizzle Fry is offline   Reply With Quote
Old 07-15-2007, 10:27 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Count me in getting ready to also do this..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-15-2007, 01:14 PM   #7
Frizzle Fry
Here you go. The final pics with everything back together turned out pretty dim, so I'll have to get more of those. The line is routed behind the shock and I lined the entire length with harness liner for extra protection:
Old 07-15-2007, 04:23 PM   #8
jandones
jandones's Avatar
looks sicc! good job man
jandones is offline   Reply With Quote
Old 07-15-2007, 07:55 PM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
With you air line coming strait out of your bag, does it kremp over or rub inside ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-15-2007, 08:03 PM   #10
itsmike2k
Looks good.. I know what your saying about the "less fittings" idea... I might do like you did.. I think the bulkhead would look pretty cool though, not that you can really see it once everything is in ... I used swivel 90's comming off my bags though..
Mike
Old 07-16-2007, 12:08 AM   #11
Frizzle Fry
If I had elbows I probably would have used them and drilled the grommet hole lower. I put the hole high enough to keep the line from kinking and low enough to keep it from touching anything. It's a tight little bend but doesn't kink. I massaged it over and made sure the radius would work before bolting the upper plate on.
Old 07-16-2007, 12:13 AM   #12
SCOTI
SCOTI's Avatar
Are there specific 'high temp' capable grommets for high temp areas like this?.
I used some 'generic' grommets to protect my door speaker wiring. After only 1 'season' of use, the grommets split & fell out leaving the speaker wire to rub the metal edge. If that's what happens in exterior heat, what would happen when exposed to under hood temps?
I prefer the bulkhead type P.T.C fittings. But, like you guys mentioned, using these can add to the possibilities of air leaks. Since this area isn't exactly the easiest to navigate when trouble-shooting 'leaks' & I didn't feel comfortable w/the longevity of typical rubber grommets, I made 'custom' grommets using 5/16" fuel line.
The fuel line passes through existing holes in the crossmember & I used nuts that are threaded on to the rubber to keep it in place where it passes through the c.member.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-16-2007, 11:20 AM   #13
Frizzle Fry
You make some good points Scoti. I don't claim to be an expert with this stuff, though I do work with pneumatic systems in my job they are not on automotive apps. So I'll definately be watching the grommets to see how they perform.
There are some bulkhead "pass-thru" fittings that look like normal bulkead fittings but the airline passes straight through without cutting. Those would be perfect for this.
Old 07-16-2007, 11:46 AM   #14
jimmydean
jimmydean's Avatar
I routed mine like that, only I then fed it through the J-bar hole (large hole you see above the header) with a section of vacuum line over the top and ran the hose on the inside of the frame. It looked great and seem to work well.
I used a nylon version of the same cable hold downs.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-16-2007, 12:23 PM   #15
b&a72
Active Member
b&a72's Avatar
Are those 9/16 botls through the top plate?
b&a72 is offline   Reply With Quote
Old 07-16-2007, 02:18 PM   #16
Frizzle Fry
9/16" heads 5/16" threads.
Old 07-16-2007, 03:27 PM   #17
SCOTI
SCOTI's Avatar
I guess this pretty well describes what I installed (albeit the busted knuckle garage version).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-17-2007, 01:58 AM   #18
itsmike2k
Well i drilled the holse and used my Bulkheads tonight.. It looks good, we'll see if i have problems in the future..
Mike
Old 07-17-2007, 06:30 AM   #19
onehot69stepside
onehot69stepside's Avatar
I like the fittings and the frame and work looks good.
But i think unless you have some longtube or shorty headers that dump in the rear, it looks like your exhaust will be too close for the lines.
:mp:
onehot69stepside is offline   Reply With Quote
Old 07-17-2007, 09:48 AM   #20
itsmike2k
Yea i thought about that, my plans are to run rear dump S&P type III headers, I hope they clear.. If not back to the drawing board . I can run a 90 right off the xmember and get into the frame rail quicker if i need....
Mike
Old 07-17-2007, 11:17 AM   #21
69burban
Garage Built Rides
69burban's Avatar
I just drilled mine straight through the top of the spring cup, right in line with the fitting on the bag. I cleaned up the hole pretty smoothe with a rasp, I plan on putting the valve as close to the bag as possible. I use this line on the pneumatics at work, pretty tough stuff. the pic is a temporary setup I made just for testing, but the hole is what I'll use.
69burban is offline   Reply With Quote
Thread Tools
Display Modes
