Old 07-23-2007, 02:18 PM   #1
trukindud
trukindud's Avatar
Question five lug front conversion
i have a 68 i was told that you could use the front spindules off a 85 or older should work but the guy before converted it to a 3/4 ton can i just change out the ball joints or do i need the hole a arm ?
trukindud is offline   Reply With Quote
Old 07-23-2007, 08:28 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: five lug front conversion
Welcome to the board from South Mississippi! When he converted it to 3/4 ton did he change the control arms or just the spindles?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-07-2007, 11:49 AM   #3
trukindud
trukindud's Avatar
hole thing
Old 10-07-2007, 03:35 PM   #4
mvfd70
mvfd70's Avatar
About the only difference between 1/2 and 3/4 ton trucks are the springs, spindles, and rear axles. If you're wanting to convert to 1/2 ton 5 bolt then swap in 1/2 ton springs, spindles. Of course you'll have to change the rear end to 5 bolt too if you want it to match. Pretty simple swap. You don't HAVE to change the front crossmember but a lot of guys do.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Thread Tools
Display Modes
