Old 07-23-2007, 03:53 PM   #1
StepinNJ
TuTone Silverado
StepinNJ's Avatar
Wheel spacer question
I have 20 X 9's all around on my 79 Step but the back wheels tuck in a little too much for my taste. Closer than the fronts do. What size spacer should I use to get them to come out a bit? Who makes them also?
Dave
13 Corvette GS vert
13 Ram Laramie Longhorn
11 Wrangler Sahara unlimited
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
08 HD Road King Classic
68 HD Golf car
StepinNJ is offline   Reply With Quote
Old 07-23-2007, 04:00 PM   #2
robin58
Re: Wheel spacer question
Without being silly in my answer, that would really depend on your backspacing/offset of the wheels you have on there. Only you can tell how much further you want to move those wheels out. If it's a small amount, then most of the regular catalog places (e.g. Jegs, Summit etc) sell thin spacers. If you need something more than that, then I'd deal with someone reputable. I have used wheeladapter.com in the past to make some for me but there are many others who do this.
robin58 is offline   Reply With Quote
Old 07-24-2007, 10:52 AM   #3
StepinNJ
TuTone Silverado
StepinNJ's Avatar
Thanks, I found Summit to be way too expensive. I found adaptitusa.com to be the cheapest so far. $49.75 for a 5x5 to 5x5 with 1.5 inch spacer with free shipping. Will try them. I have about three inches to the edge of the back fender but I don't want to go that much.
13 Corvette GS vert
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
68 HD Golf car
Old 07-24-2007, 10:09 PM   #4
slugish
Slugish
Wink Re: Wheel spacer question
wheeladapter.com are 65.00 each . made to order any size. Idont know if these are any better than the 49.00 ones, but he said he uses top grade american aluminum. for what its worth .
slugish is offline   Reply With Quote
Old 07-25-2007, 03:45 AM   #5
75silverstep
KEEP ON TRUCKIN.
75silverstep's Avatar
Is that truck of yours like the avator yet ..
1975 C-10 STEPSIDE (ALMOST DONE AGAIN)90 percent done wheres that other 10 haha .1994 GMC Z71 .
75silverstep is offline   Reply With Quote
Old 07-25-2007, 03:10 PM   #6
StepinNJ
TuTone Silverado
StepinNJ's Avatar
Almost. Here is a real pic.
Dave
13 Corvette GS vert
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
68 HD Golf car
Old 07-25-2007, 10:35 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Just curious,... are your wheels actually 20x9? They look like the Boss 305's. I thought they only came in an 20x8 inch rim. The most "popular" 5 on 5 version of those wheels have a 5 inch backspace. Just wondered. Most 8" rims will measure 9" from "outside lip to outside lip". A rim is measured from the tire bead surface. I just thought a 9" rim should be closer to the edge of the fender lip than your pictures show.
Keith
Convert to disc brakes.
Old 07-25-2007, 10:50 PM   #8
StepinNJ
TuTone Silverado
StepinNJ's Avatar
It is actually the Boss 304 and it is 20 x 8.5. My mistake. I was thinking of my other rims.
13 Corvette GS vert
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
68 HD Golf car
Old 07-26-2007, 01:49 AM   #9
75silverstep
KEEP ON TRUCKIN.
Dave
I was the one who did you picture in your avator was woundering if you actually got it down that low..keep up the good work i like your truck..
Old 07-26-2007, 07:48 AM   #10
lolife99
lolife99's Avatar
StepinNJ,... I guess I got my Boss numbers wrong. What backspace you you have on your wheels? And could you swap out the rears to a 9.5 or 10 inch wide rim to correct your problem?
Keith
Old 07-26-2007, 04:24 PM   #11
StepinNJ
TuTone Silverado
StepinNJ's Avatar
Not sure of the back space but if I did swap to a bigger rim wouldn't I have to change tire size? Would the bigger rim size alter the tires I have now? I have 275/45/20's.
13 Corvette GS vert
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
68 HD Golf car
Old 07-26-2007, 11:16 PM   #12
lolife99
lolife99's Avatar
I do know they make a 22x9.5,... hmmmm,....
Keith
Thread Tools
Display Modes
