Old 07-24-2007, 10:23 PM   #1
Zilverado
Zilverado's Avatar
Fuel Tank Selector Switch
OK, so where is the best place to get a selector switch for the R/L fuel tanks. Mine has finally given up. I have to really play with it to make it connect - - at least I assume this is a switch problem...
I believe the switch is factory. It's a grey toggle located just to the left of ash tray.
Any thoughts.
Zilverado is offline   Reply With Quote
Old 07-25-2007, 02:14 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Fuel Tank Selector Switch
I was having the same problems , ordered mine from the LMC Catalog and it works like a charm
John
Malo83 is offline   Reply With Quote
Old 07-25-2007, 02:38 PM   #3
Zilverado
Zilverado's Avatar
Thanks - I just picked one up at the dealer this morning ($24), so I'll put it in tonight and see how she works...
Old 07-25-2007, 04:04 PM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
Say Zilverado did you get that Qjet dialed in
John
Old 07-25-2007, 06:02 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
did you try pulling it apart and cleaning it up first?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-25-2007, 08:41 PM   #6
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
the switch should be black i just scored one from a buddies parts truck. guess ill keep it for when mine goes bad or change it know cause mine grey and i want black.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 07-25-2007, 09:44 PM   #7
Jray1977
But how 'bout this?
Mines an aftermarket, or as in not originally installed, put in after the truck was bought. Wanna use both the tanks, how do I see about figuring out what kind it is, brand etc..
Got a GM registered switch, should I try it? Heard horror stories of mixing aftermerket with OEM...
Right on, thanks!
J-Ray
Jray1977 is offline   Reply With Quote
Old 07-26-2007, 01:26 AM   #8
Zilverado
Zilverado's Avatar
Well, got the new switch installed and all is back to normal
John
Yes, I actually brought it into a local shop to be set up. $45 later and she's starting and running great.
Carb - Yes, fuel selector switch - No. Actually I broke the switch taking it out, but the new one solved the problem.
Yes the new one is black and actually has legible writing on it.
Originally Posted by Jray1977
But how 'bout this?
I don't know about the "horror stories", but as long as you figure out what the wires do, it should be straight forward.
Thread Tools
Display Modes
