Old 07-30-2007, 06:41 PM   #1
Johns70
Johns70's Avatar
rear axle question?
i'm putting a 77 rear axle in my blazer and had to cut the pads off of axle.when do you check pinion angle? relaxed on the springs or do you have to put tires on and set on the ground? what angle should it be at? thanks for the help john.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 07-30-2007, 09:47 PM   #2
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: rear axle question?
With the weight of the vehicle on the springs.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 07-30-2007, 10:04 PM   #3
Johns70
Johns70's Avatar
anybody have an idea what degree the factory pinion angle is?
Old 07-31-2007, 01:11 AM   #4
Livrat
Member #1049
Livrat's Avatar
Here is a link about pinion angles
http://www.carcraft.com/howto/91758/index.html
Livrat is offline   Reply With Quote
Old 07-31-2007, 11:54 PM   #5
Johns70
Johns70's Avatar
thanks i'll give that a read on days off.
Old 08-07-2007, 01:02 PM   #6
Johns70
Johns70's Avatar
so would you guys say a 3 degree angle is ok for a 4 wheel drive rear axle?
Old 08-07-2007, 01:35 PM   #7
Musclerodz
3 degrees would be very close. If you need more or less you could always use pinion shims.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 08-07-2007, 02:35 PM   #8
Burt4x4
Burt4x4's Avatar
First = what kind of drive line do you have? CV or no CV?
With CV you can point your pinon directly at the transfer case (full load on springs).
With out you need to get a degree finder/pointer and get your rear pinion/yoke angle with in 2deg of your xfer case flange/yoke. That is the perfect setup but there is a bit of room for error but too much error you will get vibrations from hell.
Oh and full load on the axel before you set and weld your perches on.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-08-2007, 11:41 PM   #9
Johns70
Johns70's Avatar
no cv just the stock driveline. i got the tires on and sitting down with all the weight on it. so i'll shoot for three or two. it'll havee to wait to get welded intall my next days off. thanks for the help, john
Thread Tools
Display Modes
