Old 08-03-2007, 02:02 PM   #1
Texasdeere
Texasdeere's Avatar
BB Corvette Exhaust Manifolds?
Has anyone tried using Big Block Corvette exhaust manifolds on their 67-72 truck. Thinking it might be a decent alternative to headers if they will fit? Better than stock manifolds anyway.
If anyone has tried this let me know,
Texasdeere is offline   Reply With Quote
Old 08-16-2007, 05:22 PM   #2
Texasdeere
Texasdeere's Avatar
Re: BB Corvette Exhaust Manifolds?
Anyone?
Old 08-16-2007, 05:35 PM   #3
Texasdeere
Texasdeere's Avatar
Here is a set for the 70-74 models. The turnout is a little different on the drivers side.
Old 08-16-2007, 06:22 PM   #4
Mt Man Chad
Mt Man Chad's Avatar
Sounds like a great idea to me!
But I have never tryed to see if they fit a truck!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 09-26-2007, 11:40 AM   #5
Texasdeere
Texasdeere's Avatar
I ordered a set today. I will let everyone know if they fit or not.
Later
Old 09-26-2007, 02:32 PM   #6
BCOWANWHEELS
where did you get them. i,ve been looking for a set for a while now.
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-26-2007, 03:37 PM   #7
Texasdeere
Texasdeere's Avatar
I ordered them from Midway Auto Supply online. They are made by Dorman and are $130 to $140 each plus free shipping.
The Dorman Part #s are: DOR-674-505 (pass side)
DOR-674-506 (drivers side)
http://www.midwayautosupply.com/p-42...h-674-505.aspx
http://www.midwayautosupply.com/p-42...h-674-506.aspx
If you buy the ones from the Vette suppliers with the correct GM stamp they go for about $600 each!
Old 09-26-2007, 05:38 PM   #8
72 Cheyenne402
72 Cheyenne402's Avatar
I am in the market please let us know if they fit
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 09-26-2007, 08:50 PM   #9
BCOWANWHEELS
thanks TEXAS C10 for the time you took to share the link so we can get a set also.
BOB
Old 09-26-2007, 08:57 PM   #10
Texasdeere
Texasdeere's Avatar
It will be about a week before I get these on for a test fit. I will be installing new motor mounts too. I have the 72 factory BB stuff on there now but the pass side is sagging pretty bad. So new rubber replacements are on the way for both sides.
Old 10-01-2007, 09:54 PM   #11
Texasdeere
Texasdeere's Avatar
I got the manifolds in this evening. I got started but nothing for sure yet. I am going to remove the pass side header tomorrow (drivers side is out) then install the new motor mounts. Both engine mounts are sagging pretty bad. Hopefully I will have something for you guys tomorrow evening!
Old 10-01-2007, 10:46 PM   #12
streetstar
streetstar's Avatar
i will be paying attention to this -- those will look better on my stock 454 engine swap than headers--- i hope they work well for you
streetstar is offline   Reply With Quote
Old 10-02-2007, 06:25 PM   #13
Texasdeere
Texasdeere's Avatar
Well they aint gona work.
The drivers side fit well, but would have required some trimming on the top of the motormount. About 3/4" would need to come off the top back corner of the part that stays on the block. This side manifold actually fit very well.
The pass side would only require 1/4" trimed off the pass side mount in the same place, but the exhaust would dump right into the frame rail. It is real tight and a lot of lines would have to be moved and I am not willing to cut the frame at all.
The engine is jacked up in the pictures. If it was set down the pass side would dump into the frame.
The bottom pic shows what would need to be trimmed on the mounts, but the right side manifold just isn't going to work.
Thread Tools
Display Modes
