Old 08-06-2007, 03:47 PM   #1
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
What is the best way
Hey Roomies I got a question!
I just bought a High energy polyy kit for my Blazer whats the best way to go about installing it? Also What is the best way to untack those welds on the bolts so I can get new ones?
Angelse68cal is offline   Reply With Quote
Old 08-06-2007, 04:04 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: What is the best way
It is best to do one side at a time. I used a cutoff wheel and carefully ground the tack weld off of each bolt. A few of the bolts I had to grind the complete head of the bolt off and punch it through the floor to remove it. I also had to use a v-chisel on my air hammer to cut one of the metal sleeve on the passenger side bolt near where you feet go.
Use a jack or two to lift one side of the vehicle and get the old rubber out and put the new poly mounts in place. I believe I have heard you should put a little lub on the poly mounts to cut down on squeeks.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Thread Tools
Display Modes
