Old 08-07-2007, 04:39 PM   #1
762wdblazer
swapping to 6 lug
have a 76 2wd blazer and looking at swapping to 6 lug brakes around have a friend swapping to 5lug on 2wd 64 p/u main question can i swap his take off parts on my 76???? if not what parts are needed to preform swap
thanks
762wdblazer is offline   Reply With Quote
Old 08-07-2007, 11:08 PM   #2
bagged74
its just $$$$$
bagged74's Avatar
Re: swapping to 6 lug
why?
bagged74 is offline   Reply With Quote
Old 08-07-2007, 11:12 PM   #3
1969k10stepside
The spring perches and shock mounts will need moved atleast.Easiest way would be to swap in a 73+ 1/2 ton 4wd ( 6 lug) rear axle.It would be a bolt in job no cutting or welding required
1969k10stepside is offline   Reply With Quote
Old 08-08-2007, 12:00 AM   #4
rcbildr
rcbildr's Avatar
Somebody correct me if I'm wrong,.... but doing that swap would be going backwards....kinda. IIRC the 64 will have drum brakes on the front and your truck has disks. As was said before, you would have to modify the rear axle too...the 64 has coil springs and your truck will have leaf springs on the back. Best bet would be to find a newer truck and raid the parts off it.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 08-08-2007, 01:08 AM   #5
762wdblazer
my blazer is a 2wd w/ drum brakes... i have 22 inch rims 6 lug from my tahoe(lease return) boyd coddingtons just sitting around and trying to make them work.
my thought was axle's and drums from rear of 64 to put in they are both 12 bolt rears
2nd front are both drum brakes so was wondering if hub/drum would bolt on.
not whole rear end just axles and drums
thanks for info so far sorry i didnt give all info
Old 08-08-2007, 08:17 AM   #6
bagged74
its just $$$$$
bagged74's Avatar
your 76 should not have drums on the front.
Old 08-08-2007, 09:05 AM   #7
762wdblazer
it does!!!!!!!!
Old 08-08-2007, 07:42 PM   #8
streetstar
streetstar's Avatar
Sell the rims and use the proceeds (plus a little more) to get what you need rather than doing a backwards swap around
streetstar is offline   Reply With Quote
Thread Tools
Display Modes
