Old 08-08-2007, 07:50 AM   #1
250/overdrive/what gears?
I want to built a truck for economy.It`ll be a shortbed with a 250-6 and 4L60E or 700r4.I`m wondering what gear ratio I should go with to keep it up in o/d but be as high as possible for mileage.Too high gears around town can dog your mileage.I may go with a manual overdrive which will give more control,but I`d want it to be able to stay in o/d as much as expected going up hills.
has anyone played with this idea or had any actul experience with doing this?My thoughts are the 3.08s are out.Maybe 3.42s,or do I need 3.73s?
Old 08-08-2007, 08:38 AM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: 250/overdrive/what gears?
I have been real happy with 3.73's in my trucks set up like you are talking about.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 08-08-2007, 10:06 AM   #3
mvfd70
mvfd70's Avatar
I'm using my 250 and going to put in a later model 5 speed transmission. Either a T-5 or a NV3500. I'm going to start out with my original 3.73's. I've heard they work pretty well for an overdrive set up.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 08-08-2007, 12:09 PM   #4
Willy Prost
I have 3.73 with the Tremec TKO 5-speed.
Unless you live in a land of no hills, I think a 3.42 rear would mean that you wouldn't use the OD very much without lugging the motor.
Willy Prost is offline   Reply With Quote
Old 08-08-2007, 12:31 PM   #5
That`s what I`m wondering.These trucks didn`t have 3.42s,right?It`s not that much taller than 3.73.I know that with 4.10s and o/d a truck is very hiway friendly compaired to w/o o/d.So,3.73 would be better and help keep some grunt still.Maybe 3.42s would be good with a 283 or 292.
Old 08-08-2007, 04:04 PM   #6
2bits
2bits's Avatar
Well, you said you wanted to build it for economy, my Stepside with a 250 l6 in it has 2:72 gears and it runs great. Depends how much freeway driving you do, I have a 45 min commute to work, so I wanted to maximize as much as I could with what I had. I wish I could drop a 4 speed in!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 08-08-2007, 06:19 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Tim, I'd go with the 3.73 personally.
there were no 3.42s in these trucks.
Old 08-08-2007, 06:32 PM   #8
What trans do you have,now.Do you have o/d?I`d go taller gears if I wasn`t going o/d.
Old 08-08-2007, 06:35 PM   #9
powell72
powell72's Avatar
If it helps you any special, I turn 2500 RPM's at 70 MPH with my 700R4 with 3.73's and 275/60/15's.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 08-08-2007, 06:41 PM   #10
Yeah,that helps...thanks.
Old 08-08-2007, 07:06 PM   #11
bad6772
Official Site Guitar Shredder
bad6772's Avatar
id run good ole 4.56s lol . forget the gas milage
bad6772 is offline   Reply With Quote
Old 08-08-2007, 07:21 PM   #12
Longhorn Man
and in all reality, you can do 2500 RPM at 65 with 3.07 gears, and spend a WHOLE lot less money.
Old 08-08-2007, 09:21 PM   #13
Yeah,I bet a 250/4speed(like M-21s etc)/3.08s would bean economical combo.I`d want a 4spd for starting off and better range.
Old 08-09-2007, 02:35 PM   #14
2bits
2bits's Avatar
I have a new 400 behind the 250. People usually think that's crazy, but the 400 has taller 1st and 2nd gears so it helps acceleration not robs it, and when it reaches 1=1 in 3rd gear, the highway gears helps bring the RPMS down there.
I just had the tranny rebuilt when I had the V8 in it, so I can't justify to myself pulling it out right now when I have so much other to do later on I plan on a 200 R4 (built right) for an easy swap.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 08-09-2007, 04:57 PM   #15
BCOWANWHEELS
i think a 250, nv4500 & 3.73 gears would be the nuts for towing in city and highway driveing myself. i know my 250 with a 3 speed & stock 235r15 tires dont like highway speeds of over 65 mph. also it could use a lower 1st gear when loaded too for takeoff and loaded reverse also.
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-10-2007, 06:15 AM   #16
Yeah,I don`t want that high geared roll-off from a 3spd.I prolly will try to find a New Venture trans.
Old 08-10-2007, 07:25 PM   #17
Brad
Out of the carpool lane.
Brad's Avatar
Andy, I tried this once and although it worked- it wasn't ideal. The problem was that with that gearing, I had to use more clutch in 1st gear and it had a slow take off as a result. It'll work for a guy on a budget, but I didn't like it.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 08-10-2007, 07:30 PM   #18
Scott68-93-97
Scott68-93-97's Avatar
If you run the 700r4 run 3.08 gears due to the low first gear in the 700 its like having a th350 with 3.73, or run 3.42 dont worry if they didn't originally come in that truck neither did the tranny your gonna put in.
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 08-10-2007, 09:52 PM   #19
I`m not worried about the 3.42s being non-original.I think 3.08s will be too high,I know 3.73 would do(w/any trans),and I wonder if 3.42s would do since they are between those other two.If they aren`t too high,that`s what I hoped to use.I even have a 3.42 posi.
Thread Tools
Display Modes
