Still Truckless!
How do I get this thing to stop???
I have a 63 GMC that runs great but doesn't stop at all. It's drums all the way around. Got pressure in the petal but still nothing on the ground. Thanks in advance.
~James ![]() ![]() 2009 Hyundai Sonata<~~Wife's sedanomatic 1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive ![]() ![]() ![]() ![]() |
glamoros piece o' lowlife
Re: How do I get this thing to stop???
Are hoses original? These tend to collapse internally with age, it won't show on the outside but the inside can get so messed up that it won't allow pressure to the wheel cylinders.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
Still Truckless!
Dunno I'll have to check. If that's all it is I'm going to be very angry...
Proud Father
As Ivan D said i would check the lines first. He helped me out with my '82 gmc the lines was sticking and holding the brakes tight. I would probably replace all rubber lines the go from there. JOE
1969 Chevy C/10 "My dad's, May he rest in peace" ![]() 1988 GMC Suburban 1/2 ton 2wd ![]() 1952 Ford F-600 1989 Toyota P/U "The Beater" ![]() |
It Is What It Is,,,,
Plus too,, your ride is a '63, Prolly can use new brake lines anyway.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
While you are checking the lines, it would be a good idea to inspect the wheel cylenders as well. If they are original, go ahead and replace them. Safety takes priority.
Still Truckless!
Well, I tore the brakes apart. As FlatBrokeRacing mentioned the wheel cylinders were frozen all the way out. Causing my brakes to constantly rub and not be able to stop me. Now I have to replace the wheel cylinders, brake shoes, and turn the drums. Thanks to everybody for the advice.
GM ONLY BABY!!!
Are you going to change all 3 of the rubber flex hoses too?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
Still Truckless!
At this time no. Probably should but simply too low on funds.
word to the wise:
Make sure to grind smooth the brake shoe contact points on the backing plates (or replace as needed) as this will cause poor performance from drum brakes. The backing plates get grooved and cause the shoes to hang up which can cause the truck to pull on hard braking or irregular wear on the friction materials. I would also very strongly consider changing the brake lines; they are not too expensive and will make a huge difference. p.s. dont forget to completely flush and bleed the system. |
Still Truckless!
Changed the brake lines. The master cylinder died on me tho. I'm probably gonna have everything replaced before this is all over. :rolleyes;
Thread Tools | |
Display Modes | |
