Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-11-2007, 08:32 PM   #1
62 short step
62 short step's Avatar
Want to buy 81-87 4x4 u-bolts & plates for corp 10 axle
Looking for a complete set. Putting a corp 10 axle under my 61 4x4 and I need these soon as possible. Thanks, Jeremy.
62 short step is offline   Reply With Quote
Old 08-12-2007, 01:32 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Re: 81-87 4x4 u-bolts & plates for corp 10 axle
what is the diameter of your 10 bolt axle tubes- 2 3/4" or 3". if it's 2 3/4" your old plates and u-bolts should work.i have several sets of plates but all are for 2 3/4" tubes.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 08-12-2007, 03:45 PM   #3
62 short step
Thanks Jerry, but its a 3" tube.
Old 08-12-2007, 11:49 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
Exclamation Re: 81-87 4x4 u-bolts & plates for corp 10 axle
Jeremy,
i just found another set of u-bolt plates i had forgotten about, they're of a mid 80s 3/4 ton suburban that had a 10 bolt front diff. with 3 inch tubes. the only u-bolts i have are for a stock front suspension and will not be long enough for your application. you can get u-bolts in almost any configuration from your local NAPA parts store. the plates will fit in a flat rate box so if you want them, i'll sell them for $30.00 delivered.
jerry moss
Old 08-13-2007, 06:48 AM   #5
LILREDGMC
Jerry
Thanks for the heads up on axle tube diameter. I have some plates, some from 3/4, and the set from the 89 Suburban , but most of my U bolts suffer from the corrosion issues. Appreciate the info to prevent a whooooops.
LILREDGMC
LILREDGMC is offline   Reply With Quote
Old 08-13-2007, 11:21 PM   #6
62 short step
Found some. Thanks Jerry!
Old 08-15-2007, 11:01 AM   #7
62 short step
Money order is in the mail as of today! Thanks again Jerry. Jeremy.
Old 08-15-2007, 08:52 PM   #8
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: 81-87 4x4 u-bolts & plates for corp 10 axle
plates should be there by friday.
jerry moss
Old 08-15-2007, 10:46 PM   #9
62 short step
Sounds good! Thanks!!
Thread Tools
Display Modes
