Old 08-13-2007, 10:33 PM   #1
ocbaud
Garage Queen Material
new radiator question
got my new radiator today. ordered from autozone, model #cu730. listed as a 4 core heavy duty radiator.
here are the pics.
and the question i had... its listed as a 4row radiator, but here are only 2 oversized rows inside of it... it looks like it will do the job, but i'm just wondering here.
and yes, it is plastic and alum, but i'm fine with that
ocbaud is offline   Reply With Quote
Old 08-13-2007, 10:34 PM   #2
ocbaud
Re: new radiator question
oh, and i need the rubber and brackets for it now
guess a dealership should have those right?
Old 08-13-2007, 11:16 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I bought my bracket and rubber spacers from www.lmctruck.com.
Bracket $19.99
Rubber $4.99 each!! you need four!!
The radiator looks identical to the one I installed on my truck. Go www.jcwhitney.com and order the zinc anode. The anode will help reduce corrosion inside the radiator.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-13-2007, 11:35 PM   #4
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
looks like it will do the job i just installed the old style 4 core and yes it has 4 little hole all the way across but i would be happier with yours the larger hole allow mor eflow i think and less chance of clogging.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 08-13-2007, 11:37 PM   #5
msgross
msgross's Avatar
what did that run, $175?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-13-2007, 11:38 PM   #6
ocbaud
$200 shipped
and g, you have a part number for the bracket and rubber mounts? there are like 2 different brackets and a load of mounts and i'm not positive which ones i need.
Old 08-14-2007, 02:40 AM   #7
Pyrotechnic
Pyrotechnic's Avatar
I was hoping to score an aluminum one equivalent to a copper 4 row for more cooling. I asked for one for a 454 1 ton truck. The one they pulled out ended up being old school copper but with as much trouble as I had finding one I just took it since the price was good and the copper brass construction is proven. I was a little scared of the plastic tanks at first but if all these newer cars are running around with them, then they must be good.
Pyrotechnic is offline   Reply With Quote
Old 08-14-2007, 03:38 AM   #8
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Plastic tanks hold up fine, I've more than once ran my over 4200lbs of a landyacht with its stock near 20-y-o radiator for well over 12 hours non-stop on some fairly nasty roads and nothing breaks, nothing leaks, and it ain't like the motor don't get hot, over 210F all the time. Just pay attention to the way the plastic tanks are clamped to the metal core, that's where most of them radiators fail and develop leaks.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 08-14-2007, 06:42 AM   #9
gchemist
gchemist's Avatar
32-0988 for the bracket. I'm not so sure on the rubber. The catalogue has changed. I'll see if older copies ID the parts better.
Old 08-15-2007, 10:57 PM   #10
ocbaud
you find anything else out g?
i went up to the dealership but they didnt have one. although you would not believe what they DID have.
an oem dash for the truck! and they gave me a $50 discount that brought it down to $325 just gotta wait till i ship off this POS one from chevyduty and go up and pick up the new one
Old 08-15-2007, 11:09 PM   #11
79Silv4x4
Workaholic
79Silv4x4's Avatar
The 4 core I bought from Oreilly last year had the true 4 cores and was considerably thicker than the stock 2 core. I had to buy the rubber mounts (top & bottom) plus a new top plate and shroud.
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 08-16-2007, 12:30 AM   #12
nico
nico's Avatar
I have the same exact radiator in my 383 powered 84 C10 and couldn't be happier! It holds up great, cools very well (even in Oklahoma heat...) and looks nice, even with my two black transmission coolers attached to it... I also had no reservations about the plastic tanks, but am very careful with the plastic filler neck... Be careful with those hose clamps!
nico is offline   Reply With Quote
Old 08-16-2007, 04:22 PM   #13
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
The plastic radiators are throw away peices, once they leak most cant be fixed so they get tossed and have to buy a new one. I have the cheap replacement plastic radiator in the 73 and it works great though.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 08-16-2007, 04:39 PM   #14
Malo83
Cruzzzn' Vet
Malo83's Avatar
Originally Posted by ocbaud View Post
$200 shipped
Eric, looked at an older LMC catalog and they recommend these new pads and brackets when going from a 2/3 row rad to a 4 row
#32-0946 x1 Bracket
#32-0947 x1 Bracket
#32-0972 x4 Pads
Malo83 is offline   Reply With Quote
Thread Tools
Display Modes
