Old 08-16-2007, 11:18 AM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Radiator and Electric Fan
Can any of you guys give me some direction on what is the best set up on this?
'83 Stepper with a 350 transplant, which came with a new 4-core radiator. I guess the fan shroud wouldn't fit, and the guy said, "either big-block fan shroud or electric fan set up".
I'm not going to question why small block to small block caused the shroud to not fit, because I wanted to go to an electric set-up anyway.
So, the question is, what is the hot set-up (no pun intended). I need to have a temp (on/off) control, too.
Thanks.
Starting all over again...This time with an '83 ...That time it was a '72.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 08-16-2007, 12:19 PM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Radiator and Electric Fan
I run an aluminum shroud and single 16" s-blade fan, along with a Be Cool thermal switch/relay that turns the fan on at 195* and shuts off at 175*. It pulls enough air to cool my 383 sitting in traffic in 105* ambient temps. You'll want to upgrade to at least a 100amp alternator for an electric setup if you don't already have one. Any fan worth a crap is going to pull significant amperage.
I'm into my setup for just under $200. A couple budget options would be a Mark VIII fan (big airflow, cheap & all over ebay), or a pair of LS1 fbody fans. Both will require some sort of relay & thermal (or manual) switch to operate.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 08-16-2007, 03:44 PM   #3
pcmcobra
pcmcobra's Avatar
Here's my setup on my 86:
LS1 fans off ebay/hawks thirdgen $50, flexalite controller $90 from summit, some angled aluminum stock from metalsdepot.com $12, $5 worth of hardware from home depot.
These things move some air. You could go with a less expensive contriller, there are several good ones out there, I bought the flexalite on a whim, but it works great and has some nice features.
This pic is from when I got the brackets on, and was just fitting the rad/fans back into my truck, I'll try and take some "finished" pics later.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 08-16-2007, 05:59 PM   #4
magwakeenercew2jh
Nice. Thanks, Guys.
If you have any more tips on the thermal controller and connections, etc., I'm a sponge for your knowledge.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-16-2007, 06:56 PM   #5
swb85
swb85's Avatar
You'll have to pay for them (usually 70-90 bucks), but IMO it's really hard to beat the pre-made controllers like the ones pcmcobra & I both have. All you do is give it 12v and a ground, the wires are labeled so it's nearly impossible to screw up. I hate wiring, and doing it this way is soooo much easier than piecing relays & switches together.
Old 08-16-2007, 10:47 PM   #6
Pyrotechnic
Pyrotechnic's Avatar
My dad played hell with a Flexalite VSC on his 2002. It worked decently at first but it was extremely unreliable. After that he bought a harness from Nelson Performance that connects to a pin on the PCM and uses relays to trigger the fans and since then it has been very reliable.
I like the kits that use a temperature switch that screws into the water jacket on the head or intake to trigger a relay, or two relays if you are using dual fans. I would add a manual switch as well, which only takes a switch that grounds out the temperature sensor wire.
Pyrotechnic is offline   Reply With Quote
Old 08-16-2007, 10:55 PM   #7
hardline_42
hardline_42's Avatar
I have the Mark VIII setup on my '81 Camaro and will be doing it again on my '87 SWB. I used a DC Controls fan controller which comes with all the hardware you need including a thermostat to wire it so you avoid voltage spikes. It ramps the voltage up slowly and the fan has never gone full speed (not really needed). I've also heard good things about the Spal controller. Coupled with the aluminum radiator I'm canibalizing from my '71 K20, this thing is gonna run super cool.
hardline_42 is offline   Reply With Quote
Old 08-16-2007, 11:00 PM   #8
C&C Chevy
C&C Chevy's Avatar
Mark VIII? Could you clarify, please.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 08-16-2007, 11:17 PM   #9
Pyrotechnic
Lincoln Mark VIII
Old 08-16-2007, 11:32 PM   #10
C&C Chevy
C&C Chevy's Avatar
Any specific years for those fans?
Robert
Current:
Past:
Old 08-18-2007, 07:50 PM   #11
hardline_42
Try eBay:
http://shop.ebay.com/mark-viii-fan_W...kQ20viiiQ20fan
For the controller (or the whole kit with a brand new fan) try DC Controls:
http://www.dccontrol.com/
The p/n is : F8LH 8C607 AA
Theres some good reading here: http://www.geocities.com/smithmonte/...rkVIII_Fan.htm
Thread Tools
Display Modes
