Old 08-16-2007, 09:23 PM   #1
kahmke69
kahmke69's Avatar
Brake Drum
I'm trying to remove the rear brake drums off my 12 bolt
and can't seem to get them off.
Am i missing some thing special trick or just not pulling hard enough?
1969 Chevy 1/2 ton 4x4
1972 Chevy K20
1953 Chevrolet 6400
kahmke69 is offline   Reply With Quote
Old 08-16-2007, 10:04 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Brake Drum
you may have to back off the shoes , but I find probably 50% of the time, smacking it with a 2 1/2 pound hammer breaks it free. They bind up on the hub generally. Just smack it where the cooling fins would be if it was that kind of drum.
Old 08-16-2007, 10:09 PM   #3
kahmke69
kahmke69's Avatar
Re: Brake Drum
uhhh
no cooling fins
1972 Chevy K20
1953 Chevrolet 6400
Old 08-16-2007, 10:37 PM   #4
Longhorn Man
Re: Brake Drum
smack the parts I circled in red... it sticks where i circled in blue.
Old 08-16-2007, 11:07 PM   #5
kahmke69
kahmke69's Avatar
Re: Brake Drum
i did and it didnt get any looser
how do i back off the shoes
1972 Chevy K20
1953 Chevrolet 6400
Old 08-16-2007, 11:18 PM   #6
Solego
Dr. Frankentruck's Monster
Solego's Avatar
Re: Brake Drum
Check your PM box.
I'm not prejudiced, I hate everyone.
Project SLOMO
http://67-72chevytrucks.com/vboard/s...d.php?t=430494
Solego is offline   Reply With Quote
Old 08-16-2007, 11:28 PM   #7
Solego
Solego's Avatar
Re: Brake Drum
I should have posted this to share the knowledge, so here is what I sent him.
"Mind you, I'm not even picking my truck up for another two days, so I've never actually owned a classic truck, technically. But, most cars that have rear drums and an emergency/parking brake have a brake shoe self adjuster. If you look on the backside of the assembly below the axle, you should see a small hole. In that hole you have access to the part that spreads the two shoes (see picture). It's part of the self adjuster. Loosening that with a flat head screwdriver, I believe by turning it up (leftie loosey), will loosen it up and you should be able to free the drum by whacking the hell out of it with a hammer and pulling. Hope this helps."
Project SLOMO
Old 08-16-2007, 11:28 PM   #8
jhow66
jhow66's Avatar
Re: Brake Drum
Try this:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-16-2007, 11:35 PM   #9
Solego
Solego's Avatar
Re: Brake Drum
Oops. I forgot to tell him about taking the lever off of the adjusting wheel. Thanx for bringing that up.
Project SLOMO
Old 08-16-2007, 11:38 PM   #10
Longhorn Man
Re: Brake Drum
I wouldn't pry on that backing plate, all that does is ask for trouble.
Old 08-16-2007, 11:50 PM   #11
jhow66
jhow66's Avatar
Re: Brake Drum
You just want to pry hard enough to put some pressure on drum-not enough to bend backing plate.Done this many times while saying my Sunday School lesson backwards.
Old 08-16-2007, 11:59 PM   #12
kahmke69
kahmke69's Avatar
Re: Brake Drum
the little hole
is non existent on the other side
and loosening the cog wheel
didnt seem to do anything
1972 Chevy K20
1953 Chevrolet 6400
Old 08-17-2007, 12:20 AM   #13
jhow66
jhow66's Avatar
Re: Brake Drum
the little hole
Your brake shoes are not holding the drums then. They are rusted to the axle hub. Just keep soaking in rust cutter and do as I suggested. You have two differants drums then. Check at the bottom of backing plate on the back side to see if there is an adjusting hole there.
Old 08-17-2007, 01:53 PM   #14
kyull67
kyull67's Avatar
Re: Brake Drum
I just did my rear brakes yesterday and I had the same problem as you with my right rear. Like Longhorn man said your drum is siezed to the hub. What I did was soak the hub in PB lube and then lightly hammer a srew driver in between the drum and backing plate. When you have a little gap give the drum a good blow with a hammer near the hub. Mine popped right off.
kyull67 is offline   Reply With Quote
Old 08-17-2007, 04:40 PM   #15
Longhorn Man
Re: Brake Drum
we do this many times a day at work, we NEVER pry on the backing plate, you get written up for shoving anything in there. We just smack it good a few times where I indicated.
Old 08-17-2007, 05:36 PM   #16
mvfd70
mvfd70's Avatar
Re: Brake Drum
I agree about not prying on the backing plate. A LITTLE (very LITTLE) pressure won't hurt but why chance it. Just keep smacking hit with a hammer on the hub and around the perimieter where LH Man circled. If it don't work still get a BFH out (BFH = Bigger F***ing Hammer). Worst case you'll crack the hub since it's cast, but it will be off. It needs replaced anyway, right?
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 08-17-2007, 08:51 PM   #17
longhorn70gmc
longhorn70gmc's Avatar
Re: Brake Drum
I just went through this and I offer the word patience. I had a very hard time with that but in the end it came off. Good Luck
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Thread Tools
Display Modes
