Old 08-17-2007, 12:49 AM   #1
exbbcoach
exbbcoach's Avatar
Question 72 Gas Smell
I am a new member and hope I get this in correctly. I am finishing up on a 72 Cheyenne LB. I have completely redone the interior and have a strong gas odor when I drive. There are no leaks inside the cab. I have not replaced the cardboard cover yet, would that make that much difference? Hope to be here with pics next time.
exbbcoach is offline   Reply With Quote
Old 08-17-2007, 12:51 AM   #2
tx71smallblock
tx71smallblock's Avatar
Re: 72 Gas Smell
i think all our trucks have that smell whether strong or weak. its just having the gas tank behind the seat.
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 08-17-2007, 01:09 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 72 Gas Smell
if the gas tank is sealed good, there will be no smell.
There are 3 common places on a 71/72 to cause this;
the O-ring on the sender
the neck going into the tank (caused by leaning on the filler as you gas up)
the rubber line that goes into the cab piller in back
Old 08-17-2007, 09:03 AM   #4
cdowns
cdowns's Avatar
Re: 72 Gas Smell
a worn gas cap can cause smell too
Old 08-17-2007, 09:05 AM   #5
Andy4639
Old member
Andy4639's Avatar
Re: 72 Gas Smell
Another problem is when the tank is full it will speal out the cap while you drive and with the window down you will smell it at stop lights. My 71 was bad about doing this.
I don't mean it's just running out of the truck but splashing around in the tank and hitting the backside of the cap it will smell.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-17-2007, 11:37 AM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: 72 Gas Smell
I agree there should be no smell. If all is correct.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 08-17-2007, 12:36 PM   #7
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: 72 Gas Smell
I think the line running up the B pillar Andy mentioned is a vent line. I don't have a 71-72, so I don't know if it is an open line or if it have a breather on it, but if it is open, you can try to put a breather on it. They let air in but not out. I got these off eBay for my blazer tank conversion, and they would probably work in this situation to:
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-20-2007, 10:30 AM   #8
exbbcoach
exbbcoach's Avatar
Re: 72 Gas Smell
Thanks guys I will check out the things you mentioned.
Old 08-20-2007, 03:41 PM   #9
hvychve
To The Levy
hvychve's Avatar
Re: 72 Gas Smell
I believe you guys are correct, I like the breathers glock showed, nice and pretty colors , too bad they'll be behind the seat and not seen. oh well, I think there were two types of tanks vented and non vented, I remember this due to buying a replacement gas cap, the cap makes a big difference in which tank you have. and yes , like others mentioned, sender oring, rubber lines, and for gods sake no leaks at carb..... good luck and hopefully you dont get too sick of the fumes if you end up living with it.
hvychve is offline   Reply With Quote
Old 08-20-2007, 03:54 PM   #10
Joe67
67 is sold
Re: 72 Gas Smell
I agree as well. The cardboard has no impact on the smell of gas fumes.
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-20-2007, 03:54 PM   #11
Longhorn Man
Re: 72 Gas Smell
the vent isn't supposed to vent into the atmosphere or into the cab.. .those vent things will make things WAY worse. IIRC, they vent goes up to the charchol canister under the hood. This started in 71.
Old 08-20-2007, 04:34 PM   #12
AH619
AH619's Avatar
Re: 72 Gas Smell
Dont Forget The Short Hose Just Inside And On Top Of The Filler Neck.its Bad To Dry Rot And When It Does Its Like An Open Hole Right Behind Your Left Shoulder.
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Thread Tools
Display Modes
