Old 08-19-2007, 08:20 PM   #1
RyanG
RyanG's Avatar
Harmonic balancer bolt removal
I went to the FAQ section and typed in Harmonic as the search word and nothing came up. Any way here is my situation. I pulled the motor out of my truck and put the new on in. The new one is all bolted up and the old one is on a stand. I don't know how to remove the harmonic balancer bolt to get my pulleys off the old one. Can anyone offer any suggestions. I don't have acces to air at this time. Also there is no flywheel on the old one.
RyanG is offline   Reply With Quote
Old 08-19-2007, 08:25 PM   #2
71Rat
ran out of money
71Rat's Avatar
Re: Harmonic balancer bolt removal
if your talking about the center one that goes into the crank. without air or a flexplate/flywheel to hold onto. put a ratchet on it and smack it sharply with a hammer or something hard. the sudden jerk(like an impact gun would cause) can sometimes break it lose. or you can try to put some cord into a spark plug hole and have the engine turn around untill its locked and then loosen the bolt
hope that helps, just ideas
71rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 08-19-2007, 08:49 PM   #3
cdowns
cdowns's Avatar
counterclockwise works best
Old 08-19-2007, 09:35 PM   #4
Ironhead
Ironhead's Avatar
Seeing you have the engine mounted on a stand, try threading two bolts in the crankshaft flange where the flexplate would bolt on and stick a prybar through where the stand head mounts to the engine block and engages with the bolts to keep it from turning. Good luck....
Ironhead Mike
'68 Panel 402BB
'84 Shortbox 4X4
'85 Blazer
'97 Silverado Ext. Cab
Ironhead is offline   Reply With Quote
Old 08-19-2007, 09:50 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
IIRC you don’t need to remove the harmonic balance to get the pulleys off. If this is a new motor you might as well put a new HB on it.
s/t
You are correct---it also uses the center bolt.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Last edited by Sport/Truck; 08-19-2007 at 09:56 PM. Reason: I posted then went to look at my pulleys…I was incorrect.
Sport/Truck is offline   Reply With Quote
Old 08-19-2007, 11:45 PM   #6
RyanG
RyanG's Avatar
Thanks guys for the responses...
Cdowns are you serious or just mess'n around?
Old 08-19-2007, 11:56 PM   #7
krue
Designated A-hole!
krue's Avatar
Cdowns is always serious.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-20-2007, 12:00 AM   #8
RyanG
RyanG's Avatar
So then it is a normal thread and not a left handed thread right??? And does the bolt need to be replaced once removed or can I use it again?
Old 08-20-2007, 12:45 AM   #9
krue
Designated A-hole!
krue's Avatar
It's normal right handed threaded bolt and can be used again. The harmonic balancer bolt is a belt and suspenders type deal. The tight fit of the balancer on the crank should hold it on (I think early sbc's didn't even have a bolt), but the bolt is added insurance.
www.daveramsey.com
Old 08-20-2007, 01:00 AM   #10
RyanG
RyanG's Avatar
Cool thanks man
Old 08-20-2007, 01:22 AM   #11
72lb4x4
The "are you serious" question reminds me of the time someone asked a question about how to remove the shifter er, peg on a Harley. I replied lefty loosey, righty tighty. The guy came back all huffy but a few others replied that the answer was brief, but accurate. Funny...
Usually V8 engines don't have strange stuff like left hand threads because 8 cylinders makes things pretty smooth so there's no need. V-twins have them hiding in strange places and you start to wonder after the 6 foot "extension" doesn't help...
72lb4x4 is offline   Reply With Quote
Thread Tools
Display Modes
