Old 08-20-2007, 05:45 PM   #1
72 longhorn BB
72 longhorn BB's Avatar
replacing window seals - easy?
Hi, can the window felt/rubber seals be accessed or replaced veryeasily?
I bought replacements from Brothers and now wonder if it is a straight forward job, or do I need to take the door apart to do it?
Your thoughts?
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
Old 08-20-2007, 09:43 PM   #2
JimKshortstep4x4
Re: replacing window seals - easy?
I am assuming that you are referring to what I call window fuzzies, (the seals that ride against the glass). I made up a screw driver by bending it in the shape of a "U" so that I could release the clips holding the seals in place. The seals can be pried out but it is possible to bend the door and wreck the paint
since the fish hook style clips hold on very firmly.
To get at the clips I push the glass to one side and using the blade tip on the screw driver, (which after bending is facing toward the handle) I am able to release the clips one at a time. This is done by inserting the blade tip between the clip and the door. Once the old seals are out installing the new ones is pretty straight forward.
If you are referring to the felt window runs then opening up the door is the best way to go.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Thread Tools
Display Modes
