Old 08-20-2007, 05:49 PM   #1
jorgensensc
jorgensensc's Avatar
Simple Oil Pan Question.
Hey all,
I am cleaning up the 350 in the truck, so I pulled it to paint. I dropped the oil pan and was going to use another one that I had. The confusion is that the original oil pan matches the block with only a bump out for dipstick on the driverside. The other oil pan and the one piece rubber oil pan gasket I have the bump outs on both sides of the engine for either side dipstick. The gasket has the hole on both sides, no knockouts, so both sides could be used. If I put the second oil pan (it's a little better shape than mine) and the gasket on my block without the bump on the passenger side, will it leak, or will it work okay? Thanks!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 08-20-2007, 06:15 PM   #2
Ole Blue 68
Ole Blue 68's Avatar
Re: Simple Oil Pan Question.
I've got a one piece universal gasket on my pan and haven't had any problems but i'm not too sure about the pan....
Don't the pans come with a metal plug of some sort? If that's intact then you should be fine.
Ole Blue 68 is offline   Reply With Quote
Old 08-20-2007, 06:59 PM   #3
jorgensensc
No metal plug, that's why I'm not sure if it will work. THanks for the feedback!
SHawn
Old 08-20-2007, 10:35 PM   #4
jorgensensc
TTT please
Old 08-21-2007, 10:44 AM   #5
Ole Blue 68
I say no plug for the pan, no go.
Old 08-21-2007, 11:02 AM   #6
truckdude239
truckdude239's Avatar
need [pics to see excalty what u talking about
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-21-2007, 11:27 AM   #7
Richard H.
Spanked once
Richard H.'s Avatar
If you get an after market pan such as my 7 qt , it comes with two spots for the dipstick as with most gasgets you buy. Regardless I do recommend a 1 pc gasget even if you have to trim it a little. Really reduces the leak factor all around the pan.
Richard H. is offline   Reply With Quote
Old 08-21-2007, 05:32 PM   #8
Luvlegs
Luvlegs's Avatar
wasn't this supposed to be simple? Here's a TTT for ya.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 08-21-2007, 08:21 PM   #9
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Buy a new pan(a good brand please!), a one piece gasket & a rear main seal - call me and thank me when it does not leak
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Thread Tools
Display Modes
