Old 08-26-2007, 12:49 AM   #1
ocbaud
Garage Queen Material
will this fit my truck?
http://www.classicparts.com/prodinfo.asp?number=79-507
please tell me it will!
its exactly what i've been looking for, but i'm not sure if it is the right length to fit my frame
ocbaud is offline   Reply With Quote
Old 08-26-2007, 09:44 AM   #2
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Re: will this fit my truck?
I don't know if that will fit but, I have another option for ya. Chevy 1 ton trucks have a trans crossmember that do NOT hang below the frame. It has brackets the bolt inside the frame top and bottom. The frame is alot taller, but you can use either the top or bottom brackets. I think it is a total of 5 pieces. I have a 1982 swb that is lower than yours and thats what I going to do. Mine was FREE!!!!!!
Tony Kee
Texas Square Bodies 73-87 junkie
texassquarebodies is offline   Reply With Quote
Old 08-26-2007, 09:47 AM   #3
bigblock73
yeller
bigblock73's Avatar
Tony Kee
The early 70's trucks had them too...my '73 has the same crossmember you are referring to (but mine is 3 pieces total)...and it is a 1/2 ton, 2WD. They are commonly referred to as "double hump" crossmembers.
bigblock73 is offline   Reply With Quote
Old 08-26-2007, 11:49 AM   #4
ocbaud
Tony Kee
correct, but i do not have the time to go out to junk yards and search for parts. that is originally what i wanted, and still do. but if i could find a tubular one(probably for cheaper too) i would be all for it. cant argue with the weight reduction.
Old 08-26-2007, 12:02 PM   #5
bigblock73
yeller
bigblock73's Avatar
Eric, hate to burst your bubble, but the weight differences between the two are very minimal. Besides, don't you have subs and amps in your ride...there is some additional weight over stock that you could shave.
Old 08-26-2007, 12:13 PM   #6
ocbaud
i'm making up for the subs
Old 08-26-2007, 05:30 PM   #7
knightlife
Dark Heart Motorsports
knightlife's Avatar
hey eric...when I come back to Ok to do my RAP, want me to build subs into your truck? Im pretty decent with fiberglassing
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 08-26-2007, 06:40 PM   #8
liljon285
That Guy
liljon285's Avatar
I think some welding shops can make some for you...i would want one to mine has like 12 bolts and they usually rusted in there or hard to reach!
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline   Reply With Quote
Thread Tools
Display Modes
