Old 08-28-2007, 12:06 AM   #1
NF65Fleetside
NF65Fleetside's Avatar
Steering Colum question
Hey fellas was wondering if you guys had any insight on a good colum to replace my stock one, maybe a tilt colum and or aftermarket one. Also and suggestions for rebuild kit and new wheel/hub combo. My current one is pretty loose and also since I switched to a floor shifter Im not dig'n the old gear selector and stuff.
NF65Fleetside is offline   Reply With Quote
Old 08-28-2007, 12:44 AM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: Steering Colum question
I got my steering column parts from:
http://www.truckandcarshop.com/trucks60_72/t60_049.html
Upper and lower bearings are easy to do, and all my slop disappeared.
PrerunnerRob is offline   Reply With Quote
Old 08-28-2007, 02:42 AM   #3
NF65Fleetside
Thanks rob, thats what I was looking at getting...and just re-spraying the column. Probably save cash that way too!
Old 08-28-2007, 10:58 AM   #4
PrerunnerRob
I forgot to tell you if you want to get rid of the column shifter, you can always pick up a 4 speed floor shift column.
Old 08-28-2007, 06:21 PM   #5
sanford66
sanford66's Avatar
Is that a factory automatic column you have? Hmmm. Those are hard to find around here. Joe
sanford66 is offline   Reply With Quote
Old 08-28-2007, 07:32 PM   #6
hewlett2002000
hewlett2002000's Avatar
i got a factory auto column in my shop in not using. just for info......
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 08-28-2007, 07:34 PM   #7
NF65Fleetside
yah it is but i took off the gear selection on it....I think Ill just rebuild this stock one, Truck Shop has all the parts for dirt cheap
Thread Tools
Display Modes
