Old 08-28-2007, 01:05 AM   #1
72Blazerod
72Blazerod's Avatar
Removing Hardtop glass?
Is there a simple way to take out the two side windows on my hardtop? I want to refinish it, and would like to take them out to do so. Thanks in advance!
Rod
1987 GMC Suburban 1/2 ton 4x4 (Beater)
1998 GMC Suburban 2500 4x4
1972 Olds 442 Convertible
2006 GMC 2500 Duramax Crew Cab (Sold)
1972 Blazer 4x4 (Sold)
72Blazerod is offline   Reply With Quote
Old 08-28-2007, 09:28 AM   #2
VinceY
Just need a couple more parts.
VinceY's Avatar
Re: Removing Hardtop glass?
Talk to any older glass guy to get the details. They use a small rope and something to pry with (screwdriver). You need to get the rope under the rubber on one side by prying the rubber out little by little and pushing the rope in. Once you get the rope in on one side you pull the rubber toward you and push the window out the opposite way. Small amounts at a time. Have someone on the other side to catch. You use the same concept when installing it back in place to pull the rubber lip over the opening. I installed my hatch window myself using this method, but have only watched windows being removed.
1947 Studebaker M5 project to match the camping trailer.
1950 Chev 4x4 Pickup
1958 Shasta Airflyte Travel trailer (fresh restoration)
1971 C/10 Pickup(Frame off Restoration)
1972 K5 Blazer CST (Daily Driver & My Company Truck)
1976 Honda CB750 Bobber
1988 Jaguar XJ12
VinceY is offline   Reply With Quote
Old 08-28-2007, 04:45 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
If they are rock hard and cracked good luck, mine came out w/ a utility knife
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-28-2007, 05:05 PM   #4
VinceY
VinceY's Avatar
Good one. I forgot to mention that I was using a brand new rubber to install mine.
When I had my front windshield installed by a glass guy, the rubber was so hard he actually cut his hand on it. Then on the odd day I drove in the rain it leaked like crazy so I ended up buying a new rubber anyway.
If you are going to replace the rubbers, cut the windows out.
1988 Jaguar XJ12
Thread Tools
Display Modes
