A guy with a truck
What do I have here???
Started stripping the top today for some much needed TLC. Plans are to repair all cracks, paint, and intall new weatherstripping/seals/domelights, etc before fall rolls around. Man, rebuilding this thing is $pendy! GMCPaul is making a killing off me...
I started sifting through my parts to make sure I had everything for the rebuild, and noticed my hatch struts look kinda funny. I don't think these will work as-is. Do I need a different end, or new struts altogether? Any one know what these are? Suburban? I'm lost. Also, does anyone re-pop the dome light harness and panel? You know, the one that says "Disconnect before removing top" or something along those lines, and the harness from the fuse box to that plate. Thanks -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 09-01-2007 at 03:00 AM. |
Re: What do I have here???
Well thats the same thing thats on my Blazer, so it doesn't look like anythings missing.
Evan
70 Blazer 4x4 305/sm465/np205 80 Buick LeSabre Limited 72 Honda CB350F 77 Honda Cb750K 00 Ducati Monster M900ie |
GEARHEAD
Looks correct to me also.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
"1972 C5"
Same here... Look ok
The angle iron type bracket is wrong.
IIRC both ends had brackets that are similar. The top brackets should look like the bottom ones. They should be like the smaller ones with the two mounting holes. The struts themselves are correct, just the mounting brackets on the top of each one are wrong.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
SKINNY TIRES RULE!
I just walked out to my top that is hanging in the garage. The top mounting brackets look a lot different from what you have. They are basically flat, not angle iron shaped. Those might be from a Suburban.
No repops are available as far as i know. You might be able to find them used. Or,if you cut the angle part off, you might be able to get those to work. Drill some holes and put some threaded inserts into the hatch.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Here is a correct '69-'72 pic of an extra set I have.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." Last edited by 71jimmy; 09-02-2007 at 03:05 AM. Reason: resize pic |
The LuvShack Garage
![]() That's what i have on both of my single wall tops ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
"1972 C5"
I was wrong earlier, the last pic is the kind I have too.
A guy with a truck
Thanks guys. Just bought a set off the parts board. This place rocks!
![]() Anyone know about the disconnect plate and the wiring harness, or will I have to find them used? Thanks -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Thread Tools | |
Display Modes | |
