Old 09-09-2007, 08:13 PM   #1
Rust Buster
Rust Buster's Avatar
Serpentine with factory Steering gear
Converting to serpentine system with the late model power steering pump but retaining my stock gear. Will the fittings be different?
Can anyone point me in the right direction for hoses/fitting adapters?
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 09-09-2007, 08:47 PM   #2
smbrouss70
smbrouss70's Avatar
Re: Serpentine with factory Steering gear
I assume you are talking about the serpentine setup from GMPP or off of a 90's camaro, right? I believe they are different. BUT, you can unscrew the fitting from the back of your existing pump and screw it in to the new pump. Then you can use the stock pressure hose.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-09-2007, 08:59 PM   #3
chevelle
instagram "footbraker67"
chevelle's Avatar
I switched my 67 over to a factory serpentine system, and all i had to do was use my stock metal line on the gear and find the stock style fitting and line coming from the pump(Its off of a 90s model pickup)and take it to a shop that makes hoses and have them put them together with some hose. turned out real well on mine, shouldnt be very expensive either.
chevelle is offline   Reply With Quote
Old 09-09-2007, 09:01 PM   #4
chevelle
chevelle's Avatar
I had problems with my "old" style hose running into the frame so i went this route.
Old 09-09-2007, 09:03 PM   #5
Rust Buster
Thanks for the info Chevelle. On another note, is that the air conditioning compressor on the driver's side? My other dilemma is figuring out what alternator to us with the serpentine system.
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 09-10-2007, 06:16 AM   #6
neonlarry
neonlarry's Avatar
Use one of the newer CS style alts, whichever one fits the serp bracket you have (there are different size mountings).
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-10-2007, 05:45 PM   #7
pcmcobra
pcmcobra's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=254812
I have a cs130 from my serpentine setup for sale that will work.
It works fine, had it on for awhile, upgraded to a powermaster side post, big stereo, electric fans needed some more juice.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Thread Tools
Display Modes
