Old 09-10-2007, 01:18 PM   #1
Duel72
Separating Ball Joint from Spindle?
What are you guys using to separate the balljoints from the spindles? I tried a tierod separating tool (fork) to try to knock them loose but it's not the right tool ofcourse.
Duel72 is offline   Reply With Quote
Old 09-10-2007, 01:38 PM   #2
kyull67
kyull67's Avatar
Re: Separating Ball Joint from Spindle?
Loosen the nut and hit the spindle with a small sledge where the ball joint goes through. I'd Read this first http://67-72chevytrucks.com/vboard/s...ad.php?t=22526 I just did all four of mine yesterday. Mine were original to the truck and they took alot of persuading. I ended up using the sledge and the pickle fork. Also I think It's best to start with the bottom when removing and installing them.
kyull67 is offline   Reply With Quote
Old 09-10-2007, 05:06 PM   #3
LayFrame72
LayFrame72's Avatar
I seperated mine yesterday and I used the fork. I was a little worried at first cause nothing was really happening after swinging for the fences with a sledgehammer. But then I realized I had flipped the fork the wrong way.. ..After that she came off..And about 5" of dirt hidden on/in the crossmember.
LayFrame72 is offline   Reply With Quote
Old 09-10-2007, 05:29 PM   #4
kyull67
kyull67's Avatar
Hmmm...Must be ball joint season.
Old 09-10-2007, 06:29 PM   #5
'68 longbed
'68 longbed's Avatar
that's my project somtime in the next few weeks. mine got sloppy all of a sudden. they were fine a few months ago...but they are originals with around 100,000 miles on them.
do any of the "mc-parts stores" sell the a-arms? I'd kinda like to build out the arms and just throw them on.
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. "
'68 longbed is offline   Reply With Quote
Old 09-10-2007, 07:39 PM   #6
72GMCburban
72GMCburban's Avatar
I had a 66 3/4 ton that I had to take the upper and lower arms off. Then after 3 weekends of trying everything (even broke a pickle fork) took it to the shop and had the old ball joints torched off, took then over and hour for 1 side, what a B*tch that was, now I am afraid to even attempt to swap springs.
72GMCburban is offline   Reply With Quote
Thread Tools
Display Modes
