Old 09-10-2007, 09:46 PM   #1
uncle
Pics 4 Hartrod.
Take a look. Took the pic of the d/s frame end to show what it should look like.
uncle is offline   Reply With Quote
Old 09-10-2007, 10:29 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Pics 4 Hartrod.
It doesn't look that bad, but I would like to see so more pictures. Those are so close and the lighting make them hard to see. I'm talking about the cracked bracket not the bent frame. Frame is of now worry. Can you take the hitch off allso? thanks
Rob
Hart_Rod is offline   Reply With Quote
Old 09-10-2007, 10:39 PM   #3
uncle
Re: Pics 4 Hartrod.
I'll get more pics tomorrow.
Old 09-12-2007, 08:38 AM   #4
uncle
Re: Pics 4 Hartrod.
More pics and I tried to show where the support area is.Disregard the first pic.
Old 09-19-2007, 10:24 PM   #5
Hart_Rod
Hart_Rod's Avatar
Re: Pics 4 Hartrod.
If you'll replace the broken area and take the hitch off, I'll call it good.
R
Old 09-20-2007, 04:05 PM   #6
uncle
Re: Pics 4 Hartrod.
Hitch is off. Explain what you mean by replace.
Old 09-20-2007, 05:22 PM   #7
Hart_Rod
Hart_Rod's Avatar
Re: Pics 4 Hartrod.
You mentioned in a PM that a bracket was broken and needed replaced:
"The other piece was on the pahard bar mount. It has a crack form the bushing being worn out on that end. It loosened the rivets that hold it to the frame and put the small crack that you see. I think you can just bolt another bracket on instead of having the rivets. I have several brackets. "
R
Old 09-20-2007, 06:18 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Pics 4 Hartrod.
What is a "d/s frame"? I am in the dark.
Member Nr. 2770
Old 09-20-2007, 06:27 PM   #9
MyakkaJeff
Junior Member
Re: Pics 4 Hartrod.
(d/s) driver's side
'63 C10 lwb flatbed
'66 C10 lwb stepside
'68 C10 lwb stepside (parts)
'68 C10 lwb fleetside (17 yr old son's ongoing project)
'03 HUMMER H2 (wife's)
'06 3500 flatbed liftgate (My work truck)
MyakkaJeff is offline   Reply With Quote
Old 09-20-2007, 08:53 PM   #10
uncle
Re: Pics 4 Hartrod.
The bracket is not the part that's cracked. It's the reinforcing plate that runs along the frame. I told you in the pm that I would cut that part out of another frame for you.
Old 09-20-2007, 09:29 PM   #11
Hart_Rod
Hart_Rod's Avatar
Re: Pics 4 Hartrod.
Tim,
I really don't want to disassemble the rear of the frame. Do you have another frame?
Old 09-20-2007, 09:51 PM   #12
uncle
Re: Pics 4 Hartrod.
That's the only one I have.
Old 10-05-2007, 04:52 PM   #13
Hart_Rod
Hart_Rod's Avatar
Re: Pics 4 Hartrod.
Tim,
I got home and started looking at my frame and maybe the pictue you took just confused me. On my frame it looks like there is only a short bracket that has to be replaced requiring only 4 or 5 rivets to be removed. How many rivets would have to be removed to replace the bracket on your frame? I apologize for the hassle, but this is hard to do long distance. Thanks
Rob
Old 10-05-2007, 04:53 PM   #14
Hart_Rod
Hart_Rod's Avatar
Re: Pics 4 Hartrod.
Is your frame a 3/4 ton? Maybe that's the difference. Your frame looks like it is beefed up more in the back than mine.
R
Old 10-05-2007, 09:26 PM   #15
uncle
Re: Pics 4 Hartrod.
It's a 3/4 frame and that sounds about right on the amount of rivets. The other piece can be welded without removing.
Thread Tools
Display Modes
