Old 09-11-2007, 08:11 PM   #1
67 cst swb
67 cst swb's Avatar
5" drop... do I need to...
5" rear drop springs (ECE)...
Do I need to C-notch the frame? Or just remove rubber bump stops...
I have a '68 Short Wide, will probably run a 265/70-15 rear tire... will also have a 2.5" drop spindle in front with stock V-8 springs... probably with 255/70-15 front tires.
Any thoughts or pictures...
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 09-11-2007, 08:34 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: 5" drop... do I need to...
71see10 has the exact drop you're thinking about running. He still has his bumpstops and says that it doesn't hit. I see no reason to install a notch for a 5" notch. A 6" drop is borderline depending on your driving habits. Here's a couple pics of his green one and my red one side by side. My truck has been lowered 1" more than his front and back but I think his tires are about 2" taller than mine in these pics (hint hint wink wink).
see ten is offline   Reply With Quote
Old 09-11-2007, 10:18 PM   #3
71see10
Worthless
71see10's Avatar
I see your hint hint wink wink There coming soon!!
Can't let it out yet.
71see10 is offline   Reply With Quote
Old 09-11-2007, 10:22 PM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
In what part of the state of GA is LaFayette?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 09-11-2007, 11:50 PM   #5
67 cst swb
67 cst swb's Avatar
So, see ten
Yours is...
Front 2.5" drop spindle with a 1" drop coil
w/ 255/50-17
Rear 6" drop coil
w/ 275/50-17
71see10....
Rear 5" drop coil
w/ 255/70/15 all around
My Trucks:
Old 09-12-2007, 11:05 AM   #6
rodstored-72
chevy truck fan
rodstored-72's Avatar
i agree with 71see10, i have a 5" rear drop on my '72 & have not modified the back at all & it drives just fine. i had thought about a adj. track bar, but as of right now i dont fell the need.
good luck!!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 09-12-2007, 03:36 PM   #7
67 cst swb
67 cst swb's Avatar
Who's truck is this, And what is known about the amount lowered and tire sizes...
Any help would be great...
edit* below truck is 3" front and 4" rear w/ Front 255/70-15 & Rear 285/70-15 tires
My Trucks:
Old 09-12-2007, 04:35 PM   #8
see ten
WTB this ad
see ten's Avatar
La Fayette is in the northwest corner of the state. We're in Walker county which actually touches TN and AL. The specs for my drop and tires are here http://67-72chevytrucks.com/vboard/s...=143835&page=6 . I also wouldn't say that you don't have to do any mods for a 5" rear drop. We still relocated the shocks and used a super track bar kit on both Brian's and Chuckles trucks. Here's a pic of Chuckles it has an identical drop to Brian's.
Old 09-12-2007, 06:11 PM   #9
67 cst swb
67 cst swb's Avatar
So, the above stepside has a 2.5" spindles with 5" rear coils?
What tire sizes?
My Trucks:
Old 09-12-2007, 06:54 PM   #10
71see10
Worthless
71see10's Avatar
I just went and checked,They are 255/70/15 on 15x8 wheels hope this helps! I know how hard it is to decide on wheels and tires. (months of looking)
Brian
Old 09-13-2007, 10:36 AM   #11
67 cst swb
67 cst swb's Avatar
So, 71see10...
Who owns the blue stepside? Who is Chuckles? I can't find a member under that name?
HELP me out...
What are the lowering and tire specs on each
The Fleetside... "71see10" 2.5" Front & 5" Rear drop w/ 255/70-15's Correct?
did you use the 2.5" spindle on front and just a 5" rear drop spring?
The Blue stepside....(Chuckles?) specs please?
*EDITED*
Front Drop... 2.5" drop spindle
Front Tire Size... 255/70-15
Rear Drop... 5" drop spring
Rear Tire size... 255/70-15
...Please...?
My Trucks:
Old 09-13-2007, 11:17 AM   #12
jkaylor68gmc
jkaylor68gmc's Avatar
That green truck is dewayane, my buddy that lives down the street. (FatBoys69). 67 CST SWB
That is the truck we lowered some more this past month.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 09-13-2007, 11:18 AM   #13
jkaylor68gmc
SeeTen
How much is your truck lowered and what is the overall diameter on the front and rear tires. Can you PM thta to me or post it. i don't want to forget to check back.
1962 swb fleetside
Old 09-13-2007, 12:53 PM   #14
67 cst swb
67 cst swb's Avatar
see ten's info...
"The rears are 17x9.5 with 4.75" of backspace with a 275/50. Up front is 17x8 with 4" of backspace and a 255/50. Tires are Nitto NT 450. My drop is... Front is a 2.5" drop spindle with a 1" drop coil. The rear has a 6" drop coil. I also used the Super track bar in the rear and an extreme drop trailing arm crossmember."
He wrote above info in another thread... (I edited some "where he bought" info out...) See above limnk in his post also.
So in brief... on see ten's truck...
w/ 255/50-17
Rear has a 6" drop coil
w/ 275/50-17
Plus... Super track bar in the rear and an extreme drop trailing arm crossmember.
My Trucks:
Old 09-13-2007, 01:18 PM   #15
67 cst swb
67 cst swb's Avatar
good luck!!
rodstored-72
rodstored-72,
So what drop in front with what tires...
Do you have pics?
My Trucks:
Old 09-13-2007, 02:15 PM   #16
71see10
Worthless
71see10's Avatar
Chuckels board name is 72bluz, His real name is chuck,he is my brother in law, lives right next door so I get to play with two trucks all the time!! There is a small story behind the name but thats for a different time. His truck is like mine, Both have 2 1/2 spindles in front with new stock height springs and 5" springs in rear with super track bar,shock relocators. Right now we both have 255/70/15 tires
Old 09-13-2007, 02:28 PM   #17
71see10
Worthless
71see10's Avatar
Here is See Ten's truck with the same drop and 15x8 wheels with 275/60 on all four corners.
Old 09-13-2007, 02:29 PM   #18
jkaylor68gmc
Thanks a ton. I think I am going to go about 1.5 more in the front, figured 1-inch on the springs, 1.5 on the arms and 2.5 spindles. 5-inches should be plenty.
1962 swb fleetside
Old 09-13-2007, 02:32 PM   #19
71see10
Worthless
71see10's Avatar
Tire size comparisons.
http://www.1010tires.com/TireSizeCal...?action=submit
Old 09-13-2007, 02:54 PM   #20
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Informative post!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-13-2007, 03:07 PM   #21
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I want this post so..TTT
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 09-13-2007, 03:50 PM   #22
see ten
WTB this ad
see ten's Avatar
5" is a buttload of drop for the front! Whatcha got cookin for the back end to keep it all lookin kosher?
Old 09-13-2007, 09:16 PM   #23
67 cst swb
67 cst swb's Avatar
Ok, so here are my thoughts...
Front - 2.5" drop spindles w/ 235/75-15's (28.88" tall) -
FYI- 235/75-15 is slightly shorter & narrower than a 255/70-15 (29.06")
Rear- 5" ECE drop springs w/ 265/70-15's (29.65" tall)
Should be exactly what I'm looking for...
Thanks for all the input guys...
My Trucks:
Old 09-13-2007, 09:22 PM   #24
see ten
WTB this ad
see ten's Avatar
You gotta be careful running a 15" wheel with a drop spindle. Some guys have had wheel/lower control arm interference and some haven't. I know mine rubbed when the wheels were being cut deep at speed. Brian's rub as well. I think a lot of it has to do with offset and wheel weight placement.
Old 09-13-2007, 09:24 PM   #25
67 cst swb
67 cst swb's Avatar
Going with stock Rally's at first... Stock 15x7" up front & Stock 15x8's in rear.
My Trucks:
Thread Tools
Display Modes
