Old 09-14-2007, 09:54 PM   #1
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Question Parts list
I am going to be replacing everything in my front suspension. upper ball joints. lower. and i was wondering can any one give me a total parts list for my upper and lower control arms . bushings ect, ,i am just wanting to rebuild my upper and lower control arms...and isntall my drop spindals and drop springs, any help would be awsome, im guessing i need upper /lower ball joints both sides, upper shaft and bushings. lower shaft and bushings,, is there anything else.....are these the correct terms for the shafts that run through the upper and lowers?
bad6772 is offline   Reply With Quote
Old 09-14-2007, 10:58 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Parts list
When I re-did mine I replaced everything:
Upper ball joints
Lower ball joints
Inner Tie Rods
Outer Tie Rods
Pitman Arm
Idler Arm
Upper Control Arm bushings
Lower Control Arm bushings
That's everything I can think of. I was installing a donor front end so I replaced everything just to be safe. Some of your steering components may not be worn. Hope this helps you some.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Thread Tools
Display Modes
