Old 09-22-2007, 12:38 PM   #1
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Need a '63-'66 1/2 ton lower ball joint measurement
Hi guys, Went to NAPA to look at a lower ball joint so I could get a measurement and they did not have it in stock, so no luck. I am hoping someone might have one laying around to measure. I need the outside diameter of the mounting area, where it presses into the A arm. I did this on a '96 ball joint and got 2.307" in diameter. This was done with a digital caliper. I need an accurate measurement of a 1/2 ton one to prove or disprove a thought I have.
Thanks in advance guys.
chevy_mike is offline   Reply With Quote
Old 09-28-2007, 08:58 PM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: Need a '63-'66 1/2 ton lower ball joint measurement
OK, the lower ball joint diameter is 1.975 inches, measured at the mounting area, ball joint tapers toward the top of the mount to aid in pressing it in I assume. Let me know if this is what you needed, or if you need another dimension.
PrerunnerRob is offline   Reply With Quote
Thread Tools
Display Modes
