Old 09-29-2007, 11:54 PM   #1
BCOWANWHEELS
400 engine setup any thoughts
heres the engine i,am going to install in one of my trucks any thoughts or ideas are welcome.
400 sbc .040 over 2 freeze plug block, 2 blt main with arp studs
400 crank .010-.010 balanced
pink GM 5.7 rods , balanced, arp rod bolts
sil-o-vite flat top pistons, 10 to 11 to 1 compression
dart pro 1 aluminum heads, 2.05-1.625 valves, 72 cc chambers ,200 cc runners
3 duces intake setup
hei ignition 60,000 voly coil
hi volume, hi pressure oil pump
7 qt oil pan
big tube shorty headers
comp cams steel roller rockers
aluminum water pump h/d hi flow
aluminum timming chain cover
engle cam int. lift 520-294 dur., exh lift 537-310 dur., lobe centers106
double roller chain
holley comp fuel pump
what ya think motor heads ?
3.73 gears with eaton posi
th400 with gv O.D.
HOPE I DONT NEED A STALL BUT BET I WILL.....
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-29-2007, 11:56 PM   #2
redhead69
fugedaboutit
redhead69's Avatar
Re: 400 engine setup any thoughts
get some slicks!!
Currently truckless
redhead69 is offline   Reply With Quote
Old 09-30-2007, 03:07 AM   #3
earl87gta
earl87gta's Avatar
That should be a fun toy .
I have close to that at my dads house but its .30 over I used the GM Pink riods and I used fastburn heads. I used a lt4 hot cam and roller rockers and crane roller lifters. I polished the rods crank and block before i took it to the machine shop. then had then balance every thing.
I was goint to use a TPI on it and never finished puting it together. Its going in my 68 fire bird one of these days.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-30-2007, 03:52 AM   #4
corn
You shouldnt need a converter with that stump puller...
corn is offline   Reply With Quote
Old 09-30-2007, 07:32 AM   #5
Sounds good.What carbs will it get and what stall speed will you run?
Old 09-30-2007, 09:10 AM   #6
grayw0lf
I need that kind of engine building budget!
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 09-30-2007, 10:35 AM   #7
Scott68-93-97
Scott68-93-97's Avatar
What year block? is there steam holes on the deck? Do the heads come with the steam holes drilled?
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 09-30-2007, 11:52 AM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I have heard that the Hi vol/high pressure oil pumps sometimes wash out the main bearings.I've never had it happen but most engine builders I know say the stock pump is plenty for the small blocks.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-30-2007, 12:20 PM   #9
BCOWANWHEELS
i didnt buy all this at once it was over 3 yrs to get it all together. still need a little more $$$$$ so i,am saving.
bob
Old 09-30-2007, 01:17 PM   #10
charlieo
Wow Bob, that 400 will really run ! Mines not even half that motor & it runs really strong for being @ 5000 '
charlieo is offline   Reply With Quote
Thread Tools
Display Modes
