Old 10-02-2007, 09:42 PM   #1
nvrforgotten52
nvrforgotten52's Avatar
bad oil pressure
hi,
i just got my truck back on the road and it running great... Except, the oil pressure is almost zero! and under throttle it goes down even more! it should go up under throttle. the oil level is fine. and the oil pressure was fine the first few days i drove it, than it just crapped out. any ideas?
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 10-02-2007, 09:52 PM   #2
truckdude239
truckdude239's Avatar
Re: bad oil pressure
get an after market gage and check you might find the gage to be bad
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-02-2007, 09:56 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
...and, you only need to have 10psi per 1000rpm's.
Member Nr. 2770
Old 10-02-2007, 09:56 PM   #4
nvrforgotten52
i have two aftermarket gauges and the both read the same thing. the stock one even barely reads it.
Old 10-02-2007, 09:57 PM   #5
nvrforgotten52
and i only have about five at the most and thats at idle. when you give it gas, even up in the higher rpm range, it goes to almost zero
Old 10-02-2007, 10:01 PM   #6
GREASEMONKEY72
GREASEMONKEY72's Avatar
hows the engine built and what wieght oil are you using???
buddy of mine has a 73 mustang with the 351C and had basically no oil pressure and asked him what oil he used and he said 5w30 so i had him take it out and put in 20w50 and would ya know it he had perfect oil pressure, ofcoure hes not a car guy as much as he thinks/trys to be
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 10-02-2007, 10:02 PM   #7
nvrforgotten52
yeah i always run a 20w50.
Old 10-02-2007, 10:04 PM   #8
nvrforgotten52
the engine is a sbc with a mild cam, lots of goodies, maybe 20,000 miles on it. im thinkin maybe my oil pump....
Old 10-02-2007, 10:07 PM   #9
jhow66
jhow66's Avatar
Rut-o! Need more info-did you build it?-did you install all oil gallery plugs?- Did you check bearing clearness?-
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 10-02-2007, 10:07 PM   #10
71tahoe
71tahoe's Avatar
Oil pump pick up tube may have fallen off.
71tahoe is offline   Reply With Quote
Old 10-02-2007, 10:08 PM   #11
jhow66
jhow66's Avatar
Just saw your last post. Did it do this all of a sudden?
Old 10-02-2007, 10:12 PM   #12
nvrforgotten52
the tube may have fallen off! not a bad idea. the plugs were all put in when i built it. all the clearences were fine. it ran real well for like 20000 miles than i decided to pull the motor to do suspension/ frame/ cab work on it. than when i put it back in the oil pressure was fine untill a few days after driving it. it runs good still it doesnt click or act like its not getting oil. however i dont really want to test my luck .
Old 10-02-2007, 10:56 PM   #13
71tahoe
71tahoe's Avatar
What if ... the tabs on the pump drive shaft sheared off. Low rpms could have enough friction to barely turn the pump but more rpms would slip causing lower pressure.
Old 10-02-2007, 11:53 PM   #14
WorkinLonghorn
WorkinLonghorn's Avatar
Personally I would have shut it down the instant I noticed no pressure and dropped the pan to look.I had a buddy once ("nah,it won't hurt it") who wreaked a 350 by running it with the gauge near 0.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 10-03-2007, 12:08 AM   #15
matthufham
i burned so many bearings on my first motor. it was a used motor to begin with, and i figured 10-12 psi was normal because that's what it always ran. i replaced rod bearings twice until i needed to replace main bearings..
then i bought a new motor the new motor ran at 20 psi at idle up to 60 psi cruising. now i clearly see my old engine had a bad oil pump.
matthufham is offline   Reply With Quote
Old 10-03-2007, 09:33 AM   #16
grayw0lf
Is your distributor fully seated? It could be stepping up??? Maybe?
Was the pump pickup fully seated?
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 10-03-2007, 09:40 AM   #17
cdowns
cdowns's Avatar
when replacing oilpumps i always tack weld the pickup to the pump// drop the pann and check pickup and rod
Old 10-03-2007, 05:35 PM   #18
nvrforgotten52
yeah i didnt tack the oil pick up to the pump, i should have. i havent pulled the pan yet but im planning on it. is it common of the sump to fall off? and while its off im just going to replace the oil pump and rod as well.
Old 10-03-2007, 07:56 PM   #19
cdowns
cdowns's Avatar
i've seen quite a few pickups fall off the pumps over the years
Old 10-04-2007, 12:44 AM   #20
shifty
Questionable
shifty's Avatar
check the pickup for debris. i had a problem with one of my inline 250's where, when the engine would warm up, the oil pressure would drop drastically at idle. ends up that a wad of gunk caked inside the top of the valve cover dropped off and made its way down to the pan. instant pickup clog, instant drop in oil pressure.
of course, it can't hurt to check your pressure gauge/line for accuracy.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-04-2007, 01:05 AM   #21
brianthelion02
Overdrive club
brianthelion02's Avatar
Ive seen timing gears come apart and plug the pickup,but this probably isnt the case!!!Good luck with what ya find!!!!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 10-04-2007, 04:53 PM   #22
mark's68
check your oil filter. When you remove it cut it open with a filter cutter and make sure it isn't collapsed.
mark's68 is offline   Reply With Quote
Old 10-04-2007, 07:00 PM   #23
68gmsee
Active Member
68gmsee's Avatar
Also, check for crimped oil lines. If you had it off an disconnected and reinstalled it, something may have bent or crimped the tubing.
68gmsee is offline   Reply With Quote
Old 10-04-2007, 07:13 PM   #24
arkracing
Weekend Warrior
When you took the motor out to do that frame work or whatever - did you take anything off the motor? (Distributor?)
If it was running fine for 20k and this just started happening, I would guess something got into the pickup tube silicone gasket maker is good @ doing that if you really slathered it on the oil pan etc.
my next guess would be the pickup fell off and the higher RPM "0" reading is because the hole the pump isn't low enough in the pan.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 10-04-2007, 11:47 PM   #25
nvrforgotten52
well i pulled the oil pan today and the pickup was still on, and the drive gear was hooked up. so the only possibilities left could be a clogged oil pressure line or a mechanically bad oil pump, or the collapsed oil filter idea
Thread Tools
Display Modes
